Thread: Cooling System Help
Results 1 to 11 of 11
  1. #1 Cooling System Help
    Aug 2012
    Springfield, TN
    I recently did a head gasket replacement, now I have an issue with my cooling system pulling a vacuum. Replaced the rad. hoses, new thermostat, new temp. sending unit. The Temp. gauge reads hot, but the fans will cut on/off as though it's not really that hot. As long as there is gas being applied, the cooling system circulates, but when it goes back to idling, the hoses are collapsed. Any help would be greatly appreciated.
  2. #2 Re: Cooling System Help
    Grand Rapids, MI
    hoses collapsed? water pump running backwards? (belt on right?) bad hoses?
  3. #3 Re: Cooling System Help
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    or ya waterpump isnt pumping water
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  4. #4 Re: Cooling System Help
    brunswick
    that or.. rad blocked up and need to be flushed..
    SE Level Member Peirce1970's Avatar
    Myrtle beach, S.C.
    Replace your radiator cap. I had this problem 2 months ago and put a new cap on it no problem since.
  6. #6 Re: Cooling System Help
    Aug 2012
    Springfield, TN
    I'll try getting a new radiator cap today. If something that simple fixes it, I'm going to have a fit.
    EDIT: I got a new radiator cap today, and that seems to have fixed my collapsing hose issue, however the temp. gauge inside the car still shoots up like a rocket. That being said, the fans still don't kick on instantly, so I'm assuming I picked up a bad sending unit. Does anyone have a set of exact numbers as far as Ohm readings I could pick up off of the sensor? I'm almost to the point of pulling my hair out... what's left of it anyways.
  7. #7 Re: Cooling System Help
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    bleed the system properly there could be air trapped in the water pump or the heater core
  8. #8 Re: Cooling System Help
    Aug 2012
    Springfield, TN
    I've bled the air out, that's why I'm thinking it's a bad sending unit. I'll get it figured out before the end of the week, just started a second job (gotta' be able to afford all the mods I've been pondering) so I'll have to make the time...
  9. #9 Re: Cooling System Help
    Sep 2012
    bridgeport,NY
    hoses collapsing means there is air in the system. liquid can not compress leave the rad cap off over night and come back in the morning. the level will have gone down,, just top off the coolant
  10. #10 Re: Cooling System Help
    brunswick
    have you flush the radiator yet.. i just went thru this.. i pulled my plug nothing came out.. had to use the airgun to blow out the plug.... hose's was clasping.. i put new rad cap and water pump
  11. #11 Re: Cooling System Help
    Aug 2012
    Springfield, TN
    I used the bleeder on the thermostat elbow. I'll take the cap off and let it sit for a day.
  1. Air in Cooling System?
    By tuchek in forum General Tech Discussion
    Last Post: 02-06-2012, 07:04 PM
  2. Hello Everybody, I'm having problems with my cooling system
    By ljatkins in forum General Tech Discussion
    Last Post: 10-14-2011, 08:09 AM
  3. Cooling system issues.
    By Curt7 in forum General Tech Discussion
    Last Post: 08-15-2011, 12:47 PM
  4. cooling system questions
    By ibhuff in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2011, 09:37 AM
  5. Cooling System
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 01:44 PM
