Thread: Stock pulley removal help
Results 1 to 18 of 18
  1. #1 Stock pulley removal help
    Nov 2011
    Bloomington IL
    I just got a new 3.6 from zzp and Im confused on how to take off the stock pulley and put the modular system back on. Does anyone have a write up or vid?
    05 GTP. K&N Intake and magnaflow mufflers, plog-cross-rear exhaust with 3' DP. (Soon to be 3.6 and ported SC)
  2. #2 Re: Stock pulley removal help
    You need a pulley puller for the supercharger.
    You try and do it without it and you'll screw up the shaft.
  3. #3 Re: Stock pulley removal help
    It takes a special pulley puller to take it off
  4. #4 Re: Stock pulley removal help
    GT Level Member fisher580's Avatar
    Jan 2012
    Dyersville, Iowa
    not recomended but, with an air hammer, normal 3 arm pulley puller, hammer, big screw driver, and some patience, you can get it off, my shaft is fine but and no play what so ever but again, a puller would work better, if i can find it ill post a pic of my stock pulley lol
    2001 Grand Prix GTP Coupe - Black-SOLD
    -SOLD
    2006 Grand Prix GXP - That Purplish dark red color
    -FWI, DiabloSport Trinity, and Trans. Cooler - - 6.8 @ 208 mph LOL
  5. #5 Re: Stock pulley removal help
    I live here. TLSheff's Avatar
    Thrasher Supercharger Pulley Puller/Installation Tool for Rental: 3800 Performance
    Spend the small amount and rent it and do it right. Renting the right tool will cost alot less than replacing the snout after you mess up the bearings &/or shaft trying to do it cheaply
  6. #6 Re: Stock pulley removal help
    Jan 2012
    Dyersville, Iowa
    -SOLD
  7. #7 Re: Stock pulley removal help
    ^ Don't do this. Do it right lol. If the bearing weren't messed up you were lucky,
    Intercooler guy neil sells these as well.
  9. #9 Re: Stock pulley removal help
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Am I going to be the first one to ask if he has the proper mods to run a 3.6? Looking at his sig, he is nowhere near what he needs to be running safely.
    GPONA #1 Cyber Bully
  10. #10 Re: Stock pulley removal help
    Jan 2012
    Dyersville, Iowa
    i had a spare m90 ($50) that i could get in 5 min if needed, but like i said, not recomended but its still running fine after 10,000 mi
    -SOLD
  11. #11 Re: Stock pulley removal help
    Jan 2012
    Dyersville, Iowa
    oh, and a water pump pulley (pusher?) to put it back on worked fine, but that was what its for too LOL
    -SOLD
  12. #12 Re: Stock pulley removal help
    Nov 2011
    Bloomington IL
    Quote Originally Posted by blackspike2710 View Post
    I just installed Autolite 104s and 10.5mm wires Sunday
  13. #13 Re: Stock pulley removal help
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    On a stock exhaust? Are you scanning?
  14. #14 Re: Stock pulley removal help
    Nov 2011
    Bloomington IL
    No but once its on Im getting the whole thing tuned. And I have a plog, crossover, rear manifold, and 3"dp going on as well
  15. #15 Re: Stock pulley removal help
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Quote Originally Posted by crzystve42 View Post
    Y u no get headers?
  16. #16 Re: Stock pulley removal help
    Nov 2011
    Bloomington IL
    Y u no get headers?
    Because when I bought them I was planning on only going to a 3.6 inch, not any lower. Also because Im a dumbass
  17. #17 Re: Stock pulley removal help
    Well a 3.6 is like a 3.4 on a 97-03 car. Because different blower.
    So it may work, it may not, car will tell the tale.
  18. #18 Re: Stock pulley removal help
    Nov 2011
    Bloomington IL
    Well if its my car itll take 3 tries before itll work and the other times she'll be as tempermental as a 3 year old
  1. Tensioner pulley removal
    By srspicer in forum General Tech Discussion
    Last Post: 05-08-2011, 03:36 PM
  2. Pulley bolt removal
    By Zinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2009, 07:54 PM
