you can start by one by one swapping parts around, swap the plug wire, if no change, swap the spark plug. if no change, swap the coil around, if no change swap the injector. this is to see if the misfire moves. if the misfire moves you found your problem part.
like a said one at a time, test it out, on to the next one.
