Thread: P0030 & P0135 codes
Results 1 to 4 of 4
  1. #1 P0030 & P0135 codes
    GT Level Member NR92's Avatar
    Atkins, Ia
    got a check engine light a few days ago, got it checked and its the p0030 code (HO2S Heater Control Circuit Bank 1 Sensor 1) as well as p0135 (O2 Sensor Heater Circuit Malfunction Bank 1 Sensor 1) well i cleared them just to make sure it wasn't a glitch as i always do, the code reader wouldn't clear out the p0030 code but it would the other, by time i got home i both codes were present as well as the same codes again pending.
    i started looking around and found the o2 plug got a little to close to the header and was damaged, so i replaced the sensor as well as the damaged plug on the harness side, i then inspected the wires
    completely and far enough back that it couldn't have been damaged, problem is the codes still come back after clearing and the scanner never can clear the p0030 code, im guessing because when the key is in the on position the ecu is talking to the sensor and finds an issue, now with what research i have gathered the obvious answer is that there is a damaged wire somewhere but all the wires look perfectly fine, now i was kinda wondering if another issue else were in the engine bay can cause these codes, on a previous car platform i was into it had a comin egr system issue throw an o2 sensor code and i wondered if this could be something like that
    if anyone can help me figure this out i would be very thankful
    2004 GTP Comp G -- Sold
    2006 GTO Magnuson supercharged
    2007 Ram 2500 QCSB 4x4 5.9 Cummins, Efi live, Exhaust, Intake N'stuff
  2. #2 Re: P0030 & P0135 codes
    Atkins, Ia
    bump, ideas anyone?
  3. #3 Re: P0030 & P0135 codes
    Apr 2009
    Fort Worth TX
    May have blown a fuse.
  4. #4 Re: P0030 & P0135 codes
    I'd check o2 fuse and wiring
  1. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  2. I stumped. Idles and runs ruff. Codes P0300 P0135. New Cat Last year. Help
    By siwittschulte in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-27-2012, 09:09 AM
  3. can't get rid of P0135!!
    By des19 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2012, 09:20 PM
  4. getting a P0135 code
    Last Post: 06-28-2012, 11:01 PM
  5. P0135 - replace o2 sensor?
    By dirtmaster88 in forum General Tech Discussion
    Last Post: 12-08-2010, 04:08 PM
