Thread: 97 gtp throttle body and supercharger need help
Results 1 to 8 of 8
  1. #1 97 gtp throttle body and supercharger need help
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    just to start out i have a 02 gt with a 97 gtp motor. i need to know if i can put a 02 gtp TB and SC on the motor and have any issues. the pcm is a zzp 1.0.
  2. #2 Re: 97 gtp throttle body and supercharger need help
    should swap right over
  3. #3 Re: 97 gtp throttle body and supercharger need help
    Sep 2012
    bridgeport,NY
    now what if i have a l36 TB would it be the same. its a 02 TB
  4. #4 Re: 97 gtp throttle body and supercharger need help
    GT Level Member Sushamouf's Avatar
    May 2011
    United States
    Yours is a GT? No supercharger? If so you are going to need just more than a supercharger. EDIT: nevermind, re-read your OP.
    2000 GTP - Stage 3 Heads - Gen V - 48# Injectors - Hardened Pushrods - Comp Limited Travel Lifters - LS6 Springs - Yella Terra 1.9 Rockers - S3 Phenolic Intercooler - N* TB - SD Headers - SR intake - ZZP 3.1 Pulley - Dyno Tune - Built 4T65E-HD - 12" Brake kit - SS brake lines - KYB GR2 Struts - 333WHP - 386WTQ
  5. #5 Re: 97 gtp throttle body and supercharger need help
    Sep 2012
    bridgeport,NY
    its a 97 l67 in a 02 gt body
  6. #6 Re: 97 gtp throttle body and supercharger need help
    Yes you can do it. The changes you'll notice/need to make.
    The vacuum routing is slightly different in 97 vs all other years. Look at any 98+ vacuum routing and mimick it. Basically the vacuum line makes a horseshoe around the charger instead of just to the back with another vacuum tree by the TB supplying the FP and BCS.
    The MAF table will need to be modified for the 02 TB. The maf sensors/TB's vary slightly, hence needing a table change. You can't/don't want to use an L36 TB on a supercharger. The shape on the back isn't a perfect circle as the L36 upper intake is different.
  7. #7 Re: 97 gtp throttle body and supercharger need help
    This.
    Which means you need more than that canned crap tune.
  8. #8 Re: 97 gtp throttle body and supercharger need help
    Sep 2012
    bridgeport,NY
    anyone in central new york have a tuner so when i put gen 5 blower on ill have a good tune
