Well after getting the wires situated properly on the starter the beast live(s/d)! After running for a few seconds with no codes I start to get a knock and smoke coming from the area of the spark plug wire number 4 (back of engine, middle plug) and my scan tool reads P0304, Cylinder 4 Misfire and that's it. I checked the compression of that spark plug and compared it to one of the plugs on the front and there was a huge discrepancy (40 on #4 and 105 on the other one I tested (#3 I believe, front of engine middle). While I was under the vehicle earlier connecting everything up the rear knock sensor seemed really loose. Could a bad rear knock sensor be causing my issue? These are new Bosch iridium plugs and new (Duralast I think) spark plug wires. The engine itself is a warrantied and tested engine that had proper compression. Any ideas of what it may be or anything else I can do to try and narrow down the issue with? Thanks a bunch for all the help already given! The car has at leasted started!! XD
