Thread: Concerns after installing headers :(
Results 1 to 20 of 33
  1. #1 Concerns after installing headers :(
    gardner,mass
    So yeserday i installed a set of sd headers into my 04 comp g. I got them all in and when i started the car i seen smoking so my first thought was they were leaking. Well after i extended and installed my o2 sensors today i went back and retightened all the bolt and i think what i thought was leaking was the oils burning off the headers cus they do have a funky smell aswell. I have yet to install my cat cus it doesnt fit unless i delete my res and push back the flange a bit so im running just the sd downpipe for now. On my way to my Brother in laws house tonight( still an awful smell) i started hearing a whistle type sound when my foot was off the pedal deaccelerating so i listened closer and noticed between 2-2.5k rmps there is a knocking sound that get louder as i rev but stop above 2.5k. Sow when i got there me and him decided to listen under the hood but couldnt hear anything at idle but then we heard a ping as if something like a bolt dropped on the headers so im looking arounda couple mins for a bolt or something and we hear it again. Also something to note when driving the car it seems really rough in my pedal, alot more than befor installing them so idk if thats normal or if something has to be hitting.
    So
    1) is that smell normal or do i have a leak
    2)what could cause a knock at those rmp ranges
    3) is that whistling a leak
    4) is the pining sound just the headers breaking in and warping
    5) is the riough vibration in pedal normal from more power or is something hitting
    When and after i installed them i checked everything possible they could be hitting( tran dipstick, ac tube in front i had to bend down, my front o2 i didnt have to modify cus it had about 1/4-1/2 inch of play from the firewall befor hitting, and checked all around headers and crossover)
    Any tips ideas would be great, its my first header install and im kind of worried cus its my dd. Thanks
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: Concerns after installing headers :(
    mi
    going to go on a limb and say you're overreacting
  3. #3 Re: Concerns after installing headers :(
    GT Level Member Beelzeboul's Avatar
    Racine
    the o2 sensor could be knocking I didnt mod my firewall and can feel it hitting but only in reverse the engine is going to move a little so it could be something just lose rattling around at certain ranges inclines and so fourth
    when mines hitting I feel it in the steering wheel seems like if the gas pedal is vibrating its more likely to be from your DP and lower pipe area i would check the clearance there
    does it smell like burning plastic?
    have you checked your o2 sensor wire and plug wires for heat dmg?
    I'm sorry officer I didnt know I couldn't do that
  4. #4 Re: Concerns after installing headers :(
    gardner,mass
    it does smell like burning plastic and it smelled befor i put the sensors back in
    all wires are out of the way ran behind and away from headers
  5. #5 Re: Concerns after installing headers :(
    gardner,mass
    Quote Originally Posted by siLversLeigh View Post
    im praying so but that doesnt help my thoughts
  6. #6 Re: Concerns after installing headers :(
    Probably your O2 sensor hitting the firewall. Also let the car run and get underneath it and check for exhaust leaks.
    04 Comp G.
  7. #7 Re: Concerns after installing headers :(
    gardner,mass
    ya im push in the firewall a bit just to be certain but i did however check for any air i could feel coming from every connection and couldnt feel anything atleast at idle so ima try sea foaming it and check for leaks then
  8. #8 Re: Concerns after installing headers :(
    Front header touching fan shield?
    Otherwise if you didnt clean off the headers after install, smoke is going to happen from anything like oils and grease burning off.
    And you being catless is going to make its own smell, very strong exhaust smell is always present.
    Its possible you have a leak, maybe at the egr or downpipe connection
  9. #9 Re: Concerns after installing headers :(
    gardner,mass
    most answers are things i thought but what about the knocking and the ping, those are my main concerns. What could cause something to knock at 2-2.5k rmps i can hear in car while going 30-45, loose valve? and im hoping someone will tell me that all headers ping like that as if a penny or bolt or something is hitting them hear and there
  10. #10 Re: Concerns after installing headers :(
    gardner,mass
    that was another thought the front fan shield i ripped off, i even asked drunkie when installing them and he said it should be fine
    i have about 1/4 an inch clearance when car is idle idk when im driving, anyone with 04+ know?
  11. #11 Re: Concerns after installing headers :(
    Racine
    the ping I get too after installation usually while cooling
    it could be knocking at higher rpms too and you just can't hear it over engine noise I know first hand how hard it is trying to diagnose noises while driving straight pipes
  12. #12 Re: Concerns after installing headers :(
    gardner,mass
    Quote Originally Posted by Beelzeboul View Post
    ty thats what i wanted to hear but what kind of knocking are you thinking at those rmps? valve or detonation or what
  13. #13 Re: Concerns after installing headers :(
    it will create false knock if the o2 sensor is hitting the firewall.
    04 Comp G.
  14. #14 Re: Concerns after installing headers :(
    Racine
    probably fire wall to be honest like I said especially if you can feel it in your foot its probably just echoing from the dp I found the 3inch band clamps on the Dp tend to fit a little loose and wouldn't be surprised if when the car leans back it jostles it up enough to be touching the underbody or Firewall and that as the car evens out it levels off again
  15. #15 Re: Concerns after installing headers :(
    gardner,mass
    i dont meen knock as in kr from gauge i meen i can hear a knocking at those rmps
  16. #16 Re: Concerns after installing headers :(
    Racine
    pretty sure hes talking about a knocking sound and not a False Knock retard reading but true story engine vibrations will give ya some false KR
    also on the whistling noise. using a piece of kleenex and going around headers you should be able to see a leak via motion in the paper
    if its not coming from there going around your vac lines with some starting fluid (cold Engine) and listening for a kick in the idle will help ya find vac leaks another good tip is if the car idles rough or your LTFTs are stuck at 16.4 you got a vac leak
  17. #17 Re: Concerns after installing headers :(
    gardner,mass
    its almost like a tick tick tick tick tick that speeds up the faster i go from 2-2.5k
    like a hammer tapping a piston
    i dont think ide hear injectors inside at those speeds and rmps
    also it seemed to come back after it warmed up a bit
  18. #18 Re: Concerns after installing headers :(
    exhaust leak
  19. #19 Re: Concerns after installing headers :(
    Tick tick = exhaust leak. What type of clamps did you use and did you keep the original flex or did you change it?
    04 Comp G.
  20. #20 Re: Concerns after installing headers :(
    gardner,mass
    good idea with the tissue lol didnt think of that
  1. Problems when installing headers?
    By Timing in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2012, 06:59 AM
  2. Headers installing problem...
    By szalajka05 in forum General Tech Discussion
    Last Post: 04-07-2012, 12:02 PM
  3. installing headers and...
    By c4gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-21-2011, 04:58 PM
  4. Installing Headers?
    By AmericanRiceEater in forum General Tech Discussion
    Last Post: 01-02-2011, 05:22 AM
  5. Installing Headers
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-09-2009, 02:25 PM
