Diamond pistons - waste
Boring block - waste
160* - waste
stock cam with ported heads - waste
not knowing if it is tuned or not - more of a problem.
My suggestion. Go get the PO and find out is going on 110%.
Then, go buy a stock short block, stud the heads, re-gasket and get new fluids, port the heads, run a cam of some sort because porting the heads with a stock valvetrain would be a waste. Start off with a 3.4" pulley and go from there when you have a way to tune it, because a 3.1" will be too small. Probably running the factory injectors static as well which is no bueno.
So yea
