Thread: 2000 GTP Idles rough
Results 1 to 10 of 10
  1. #1 2000 GTP Idles rough
    Sep 2012
    Brooksville, FL
    I have a 2000 GTP that idles rough. It sounds like a misfire. When I rev the engine (in park) upto 4k RPM's, the RPM's & idle will start to bounce! I have already changed the plugs, but I am unsure where to look next. Any Suggestions?
  2. #2 Re: 2000 GTP Idles rough
    stop doing that, your hitting the rev limiter, it will do this in neutral and park.
  3. #3 Re: 2000 GTP Idles rough
    What plugs and what gap?
    And yes the 4k is your rev limiter, so stop that.
    Maybe you should research more on your problem, you'd find cleaning the throttle body and MAF sensor can be very helpful.
  4. #4 Re: 2000 GTP Idles rough
    Florida
    2 things.
    Our cars, especially modded do tend to misfire at idle. Though enough to cause it to idle rough sounds like something more.
    2nd, if the car is misfiring, your check engine light will flash on and off.
    What plugs did you put in, and what did you gap them to? Are there any mods done to the car?
    How old are the plug wires? Did you make sure that they were all contacted with the plugs well?
    Does the car run okay driving, or does it misfire while driving too?
  5. #5 Re: 2000 GTP Idles rough
    The Boss Iceman6669's Avatar
    Jun 2011
    IIRC the SES light only flashes to show Multiple misses..
    Do you still have the screen in the TB? Also have you made any changes to the intake?
    2011 F-150 Yote powered
  6. #6 Re: 2000 GTP Idles rough
    Sep 2012
    Brooksville, FL
    Plugs are Autolite Double Platinum Spark Plugs, Gapped to .06! I have just taken it to the local Adavance auto parts to run the code. Misfire in #4, Also something w/ the catalyst which could also be caused by the misfire (per the guy that checked the code). going to look into that tomorrow morning. Thanks for the info on the Rev Limiter, didn't know there was one equipped on the car, clearly I'm an amatuer at best!
  7. #7 Re: 2000 GTP Idles rough
    ditch the double plats, these cars dont like them, get some nice iridium plugs, or copper core plugs.
    that will fix your misfire most likely. gap the new plugs at 55
  8. #8 Re: 2000 GTP Idles rough
    Florida
    ^ This exactly.
    If that doesn't cure the hiccup, get some MAF cleaner and clean the MAF.
  9. #9 Re: 2000 GTP Idles rough
    Stock AC delco plugs are what you want.
  10. #10 Re: 2000 GTP Idles rough
    Sep 2012
    Brooksville, FL
    Turns out it was the Coil pack for 1 & 4 Cylinders that was causing the misfire.
  1. bad idles
    By MGRead in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-29-2012, 06:18 PM
  2. 08 idles and runs bad
    By JJB in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-06-2012, 08:52 PM
  3. 2000 gtp runnig rough and black smoke
    By cjrolke in forum General Tech Discussion
    Last Post: 11-01-2011, 01:38 PM
  4. Idles for 5 seconds then dies
    By 00grandprix in forum Engine
    Last Post: 04-30-2011, 04:32 PM
  5. car idles shakes
    By handymontana in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-15-2010, 01:45 PM
