Thread: found my power loss, bill any thoughts? po350, p1350
Results 1 to 19 of 19
  1. #1 found my power loss, bill any thoughts? po350, p1350
    Aug 2012
    charleston sc
    Car on no dtc's. Haha don't think so, key to on but engine off 2 codes showed up on the scan P0350(Ignition Coil, Primary/Secondary Circuit. What's this all my coils or maybe my ICM? And the other code which I do not know is P1350?
  2. #2 Re: found my power loss, bill any thoughts? po350, p1350
    St. Louis
    P1350 should be for Ignition control (ICM), IIRC. Might want to have the ICM tested and see if it's good. Also check the wiring going to it.
  3. #3 Re: found my power loss, bill any thoughts? po350, p1350
    Aug 2012
    charleston sc
    About to post picks of the icm harness ground into the heads etc
  4. #4 Re: found my power loss, bill any thoughts? po350, p1350
    Aug 2012
    charleston sc
    Quote Originally Posted by FordMan77 View Post
    thanks, I did a little research but I think its my icm. The coils are only 102000 miles old and ive been told the icm is more sensitive to water/coolant!
  5. #5 Re: found my power loss, bill any thoughts? po350, p1350
    Aug 2012
    charleston sc
    Dealerships price: $372.86 AutoZone price:$158.00+? Is there a difference in icms?
    Quincy, Mass
    Lol I enjoy how bill is requested in people's subject lines now.
    No more GP 04 Impala SS Indy:
  7. #7 Re: found my power loss, bill any thoughts? po350, p1350
    Aug 2012
    charleston sc
    haha im new I don't know everyone yet I've read a few threads though. Could you answer hood sir?
    Quincy, Mass
    The difference in icm's is the brand. The dealer's is likely Ac delco although some of the electronics might be Delphi, autozones is probably duralast. You can also look on rockauto.com they sell Ac Delco and Delphi as well as some others and are significantly cheaper than the dealer. I also like to get the part number on rockauto and then look up the number on amazon.com because sometimes they are cheaper too.
    I think autozone can test you icm to see if it's it bad. And also check the for sale section anyone parting out a car might have a used one for you.
  9. #9 Re: found my power loss, bill any thoughts? po350, p1350
    Aug 2012
    charleston sc
    So they all work the same?
    Quincy, Mass
    They will all fit the same but how long they might last is different story. The autozone one is worth it if it has a lifetime warranty, but if it doesn't I'd go with one on rockauto, Ac delco, Delphi, or Standard would be my choices
  11. #11 Re: found my power loss, bill any thoughts? po350, p1350
    St. Louis
    I never buy electronic parts from Autozone, lifetime or not. I don't like changing parts out every 6 months even if it's got a lifetime. I don't have patience for crappy parts, lol... RockAuto FTW. If not, maybe check the above that Swiggles mentioned, or OReilly's. FWIW, when a cracked coil took out the ICM on my 00 GT I replaced it w/ a OEM used one that I had from my old motor and it still runs fine. Had 200K on it when I swapped it in and am at 279K now w/ no issues. Just sayin..
    Quincy, Mass
    Ya I definitely agree with you there. advance auto sells Delphi as well but they are cheaper at rock auto usually, sometimes shipping costs more than what you are saving.
  13. #13 Re: found my power loss, bill any thoughts? po350, p1350
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by Overboost101 View Post
    Swigs
    Why did he call you a "hood"? He doesn't even know you.
  14. #14 Re: found my power loss, bill any thoughts? po350, p1350
    Aug 2012
    charleston sc
    Quote Originally Posted by Rico View Post
    Swigs
    haha I was on my phone sorry about that and thanks everyone.
    Quincy, Mass
    Lol no problem
  16. #16 Re: found my power loss, bill any thoughts? po350, p1350
    Aug 2012
    charleston sc
    So I swapped coils and they were good then looked at the pins on the ICM they were fine also got a new ICM problem solved no codes, everything seems/feels better.
  17. #17 Re: found my power loss, bill any thoughts? po350, p1350
    St. Louis
    Good deal. Now you have to get that valve cover gasket and grommets changed so the oil leak stops, lol...
  18. #18 Re: found my power loss, bill any thoughts? po350, p1350
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    i had the same issue but mine was cuz the bolt from the wires where it plugs into the icm wasnt still loose so once i tightened that up my car hasnt studdered since.
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  19. #19 Re: found my power loss, bill any thoughts? po350, p1350
    Aug 2012
    charleston sc
    Better not I just dropped in my rebuilt l67 less than 1800 miles ago!
  1. Found a 2004 Grand Prix GTP w/ Comp package...thoughts?
    By dancadman in forum General Grand Prix Discussion
    Last Post: 06-29-2012, 02:14 PM
  2. Found a set of rims from a 2001 Mustang GT..thoughts?
    By GiAnT4LYFE in forum General Grand Prix Discussion
    Last Post: 02-28-2012, 01:58 PM
  3. power loss
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2011, 01:16 AM
  4. power loss
    By ChdMcD in forum General Tech Discussion
    Last Post: 04-15-2010, 02:57 PM
  5. power loss when hot
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2009, 03:23 PM
