Thread: Engine cranks but won't start
Results 1 to 20 of 27
  1. #1 Engine cranks but won't start
    Aug 2012
    South Carolina
    A few weeks ago engine started running rough. "Service Engine Soon" light was NOT on. My CARMD code reader returned a code P0403. I took off the EGR valve, cleaned it and put it back on. The engine was running fine after doing this.
    Last night the car started running rough again. This time the "Service Engine Soon" light came on. The engine would stall but it would start again. After cooling down the engine will no longer start. It cranks but will not start. CARMD is returning code P0403 again. Battery is good, fuel pump is priming, ignition is producing spark.
    Any ideas?
  2. #2 Re: Engine cranks but won't start
    Portland Oregon
    Sounds like maybe an electrical issue. One thing you could do to troubleshoot the egr is disconnect it and block off the exhaust and intake sides on the manifolds and see if it runs ok
  3. #3 Re: Engine cranks but won't start
    I would google the code and learn about it. I think it's a pissed off egr pintle, but didn't look it up.
  4. #4 Re: Engine cranks but won't start
    Portland Oregon
    P0403 Exhaust Gas Recirculation (EGR) Solenoid Control Circuit = PCM
  5. #5 Re: Engine cranks but won't start
    GT Level Member Beelzeboul's Avatar
    Racine
    I don't think you would have to take the whole thing off just disconnect harness or intake side hose under TB n block hole
    I'm sorry officer I didnt know I couldn't do that
  6. #6 Re: Engine cranks but won't start
    GTP Level Member Rico's Avatar
    Apr 2009
    Fort Worth TX
    Some times the pintle gets carbon on the shaft and sticks creating a good vacuum leak.
    It's a CUMMINS Dodge not a Dodge Cummins
  7. #7 Re: Engine cranks but won't start
    I googled for a full minute.
    DTC P0403
    Tons of stuff out there that suggests pintle is stuck or hung open.
  8. #8 Re: Engine cranks but won't start
    Aug 2012
    South Carolina
    Thank you all for your answers and input. I've taken the EGR valve off and cleaned it. The pintle is clean and moving freely. I've also cleaned the MAF sensor because I had read this could cause a no-start situation.
    I'm curious as to why it would retart after stalling and would run rough, but after cooling down it refuses to start. And would a faulty EGR valve prevent the engine from starting?
  9. #9 Re: Engine cranks but won't start
    Aug 2012
    South Carolina
    Just bought a new EGR valve and installed it. (I was going to do this anyway in the near future due to the re-appearance of the P0403 code - So I've done that earlier than planned.) With the new valve fitted there is no change. Engine still will not start.
  10. #10 Re: Engine cranks but won't start
    Aug 2012
    South Carolina
    UPDATE : I found a break in one of the vacuum tubes going to the TB. Fixed that and the engine started and idled for 10 minutes without problem. Took it for a test drive and everything was good until I got two miles down the road. The engine started running rough while I was stopped at a red light. Then it stalled and would not start again. I'm getting the same code from the CARMD (P0403) but the "Service Engine Soon" light is now off. Got towed home by AAA and I now have a charger hooked up because I deadened the battery trying to get the engine started.
    If anyone has any thoughts please let me know.
  11. #11 Re: Engine cranks but won't start
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    go back ovver all the vac lines.. it maybe another one off.. or check fueling
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  12. #12 Re: Engine cranks but won't start
    Could be crank sensor.
  13. #13 Re: Engine cranks but won't start
    Diagnosing..
    The only way to test a crank sensor is shotgunning one on.
    Unplug the maf sensor and let it run..wiggle wires, put it in and out of gear, don't drive further than you can push it. (A little humor..but true, cause 2 mile tow's suck)
    Take the vacuum line off of your fuel pressure regulator and with the car running put your finger over it.. got decent suction?
  14. #14 Re: Engine cranks but won't start
    Aug 2012
    South Carolina
    Ok - here's the latest.
    I disconnected the MAF sensor. The engine ran for a few seconds, surging and then died. Didn't get a chance to take the vacuum line off the fuel pressure regulator to check for suction because the engine won't start again.
    I was checking over all the vacuum lines and noticed what you can see in the attached picture. It looks like there should be something attached here but I can't see anything that looks like it fell off.
    Engine cranks but won't start Attached Images
  15. #15 Re: Engine cranks but won't start
    Nope..that one is normal. Should have a foam block over it..but rarely do you see them.
  16. #16 Re: Engine cranks but won't start
    Aug 2012
    South Carolina
    Thanks. That explains the remains of foam I found stuck around it.
    I'm going to replace all the rubber parts on the vacuum lines because they are all old and some look like they're about to fall apart. I got everything I need to do that for less than $10 at Advance so that's worth doing. I'll let you know what happens.
  17. #17 Re: Engine cranks but won't start
    GTX Level Member TEK310's Avatar
    Mar 2012
    Dallas
    can you get a close up of the full engine bay so we can look at it for you?
    2012 Competition Orange Boss 302 #1769 438rwhp 391rwtq
    intake - off road h pipe - e85 - tune
  18. #18 Re: Engine cranks but won't start
    Aug 2012
    South Carolina
    Yes - I'll do that in the morning when it's light and the rain has stopped.
    I've been reading around a few other threads and, as was mentioned by dsmuts, the CPS has been raised several times. From some of the comments made the symptoms sound very similar to mine in that when try to start the engine it will not start unless it has been sitting for a long period - then it will start and run for a short wile before dying again, at which point it will not start again. This seems consistent with the CPS failing when the engine heats up and working normally again when the engine cools down.
    Your thoughts?
  19. #19 Re: Engine cranks but won't start
    Canada
    Yes the crank position sensor will give those symptoms drive for awhile then when the vehicle is hot it will die. Let it sit for a few minutes then it will restart after sensor cools. had this happen to me
  20. #20 Re: Engine cranks but won't start
    Canada
    Sorry forgot to mention i replaced this about 5 years ogo. Iam having another problem now were the car will not start then eventually starts and the radio locks out. Anyone have this problem with there G/P also mine is a GTP.
  1. Replies: 6
    Last Post: 07-20-2021, 09:27 PM
  2. Cranks but doesn't start sometime. Help!
    By Fluid604 in forum General Tech Discussion
    Last Post: 09-29-2011, 09:59 PM
  3. Car Won't Start... Just Cranks.
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2010, 10:23 PM
  4. Engine Cranks but Will not Start
    By rockytop104 in forum Introductions/Noob Questions
    Last Post: 10-04-2010, 08:21 PM
  5. Cranks over but will not start
    By wfj8251 in forum General Tech Discussion
    Last Post: 02-08-2009, 02:47 PM
