Thread: Engine cranks but won't start
Results 1 to 20 of 27
  1. #1 Re: Engine cranks but won't start
    Nope..that one is normal. Should have a foam block over it..but rarely do you see them.
  2. #2 Re: Engine cranks but won't start
    Aug 2012
    South Carolina
    Thanks. That explains the remains of foam I found stuck around it.
    I'm going to replace all the rubber parts on the vacuum lines because they are all old and some look like they're about to fall apart. I got everything I need to do that for less than $10 at Advance so that's worth doing. I'll let you know what happens.
  1. Replies: 6
    Last Post: 07-20-2021, 09:27 PM
  2. Cranks but doesn't start sometime. Help!
    By Fluid604 in forum General Tech Discussion
    Last Post: 09-29-2011, 09:59 PM
  3. Car Won't Start... Just Cranks.
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2010, 10:23 PM
  4. Engine Cranks but Will not Start
    By rockytop104 in forum Introductions/Noob Questions
    Last Post: 10-04-2010, 08:21 PM
  5. Cranks over but will not start
    By wfj8251 in forum General Tech Discussion
    Last Post: 02-08-2009, 02:47 PM
