Thread: Dumb question about LIM and MPH
Results 1 to 18 of 18
gotgtp Dumb question about LIM and... 08-29-2012, 07:18 PM
dsmuts Re: Dumb question about LIM... 08-29-2012, 07:56 PM
gotgtp Ok that does seem logical. I... 08-29-2012, 08:07 PM
dsmuts Re: Dumb question about LIM... 08-29-2012, 08:10 PM
gotgtp I'm thinking about going with... 08-29-2012, 08:22 PM
MoarkatsINmuhtrailer No, no, no on the coil... 08-29-2012, 08:27 PM
Fivefingerdeathpunch Re: Dumb question about LIM... 08-29-2012, 08:35 PM
gotgtp I was told the MSD would... 08-29-2012, 08:58 PM
Fivefingerdeathpunch Re: Dumb question about LIM... 08-29-2012, 09:03 PM
sseilmnop MSD coils tend to fail... 08-29-2012, 09:03 PM
gotgtp I will take your word on the... 08-29-2012, 09:47 PM
Fivefingerdeathpunch Re: Dumb question about LIM... 08-29-2012, 10:17 PM
BillBoost37 Re: Dumb question about LIM... 08-30-2012, 06:24 AM
gotgtp Re: Dumb question about LIM... 08-30-2012, 09:50 AM
gotgtp Re: Dumb question about LIM... 08-30-2012, 09:47 AM
BillBoost37 Re: Dumb question about LIM... 08-30-2012, 09:49 AM
BillBoost37 Re: Dumb question about LIM... 08-30-2012, 09:51 AM
gotgtp Re: Dumb question about LIM... 08-30-2012, 09:57 AM
  1. #1 Dumb question about LIM and MPH
    SE Level Member gotgtp's Avatar
    Chicago, IL
    Will a bad/leaking LIM have an effect on my fuel mileage? I have a bone stock(performance wise) 04 Comp G. I am currently averaging 16.4 MPG
    2004 Comp G - Bone Stock except visual mods
  2. #2 Re: Dumb question about LIM and MPH
    A leaking lim will cause a vacuum leak possibly which will hurt gas mileage.
    Chicago, IL
    Ok that does seem logical. I was kind of hoping that is it. I will be replacing the gasket next weekend. I already put in a new air filter, fuel filter, cleaned the MAF, and TB about two weeks ago and it increased from 15.2 to 16.4 mpg but I think it should be a lot better than that.
  4. #4 Re: Dumb question about LIM and MPH
    When you do the lim change the spark plugs too.
    Chicago, IL
    I'm thinking about going with the NGK plugs and 8mm wires along with MSD coil packs.
    Ohio
    No, no, no on the coil packs...
    MSD sucks donkey ass.
    Stock coils are way better.
    /end of story
  7. #7 Re: Dumb question about LIM and MPH
    Stock replacement plugs are all you need.
    And if you only drive city 16-19 mpgs is pretty normal.
    Chicago, IL
    I was told the MSD would create a better spark but not last as long. And all I do is city driving being from Chicago but I don't get on it too much. Just thought the mpg should be up there at least a little more.
  9. #9 Re: Dumb question about LIM and MPH
    Well, we are telling you msd coils suck, so dont use them lol.
    Mercer, Pa
    MSD coils tend to fail prematurely.
    Chicago, IL
    I will take your word on the coil packs and go with the OEM. So for the spark plugs I should just go with the AC Delco? And also the wires?
  12. #12 Re: Dumb question about LIM and MPH
    Yup ac delco plugs and whatever set of wires you want, most stores have some sort of wires with a warranty.
  13. #13 Re: Dumb question about LIM and MPH
    I'd bet yoru issue is too much around town on 3.29 gears and enjoying the power. You aren't going to have a big enough vacuum leak to cause mpg issues
  14. #14 Re: Dumb question about LIM and MPH
    Chicago, IL
    on a side note: will the 8mm wires make any difference (spark/performance wise) if I have the OEM coil packs and plugs in? I don't want to buy them if there is no advantage to that.
  15. #15 Re: Dumb question about LIM and MPH
    Chicago, IL
    I really do enjoy the power, I don't get on too often but i guess it could be enough to lower my mpg. I think i might have to start buying lighter shoes....
  16. #16 Re: Dumb question about LIM and MPH
    I see you live in Chicago. What is your typical driving? When I was there..even though I was on the highway..I was far from cruising at 70+ for extended periods of 20+ minutes. That is a killer for mileage, especially in a 3.29's car.
  17. #17 Re: Dumb question about LIM and MPH
    Thicker wires typically mean more insulation. That's what you usually gain with thicker wires.
  18. #18 Re: Dumb question about LIM and MPH
    Chicago, IL
    I do mostly city driving, stop and go every damn intersection, rarely on the highway unless I'm going out of town. I work 15 miles from where i live and usually takes about 35-40 minutes to get there. Needless to say I'm in traffic all the time. That really can't be good the mpg.
  1. dumb question but?
    By dmack976 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-05-2012, 12:45 PM
  2. Might be a dumb question, but...
    By SteveCZ28 in forum General Tech Discussion
    Last Post: 02-19-2011, 11:06 AM
  3. Hopefully Last dumb AC Question
    By guitarguyucf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 12:48 PM
  4. Dumb question of the day
    By johnb62 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-06-2010, 12:13 AM
  5. dumb oil question
    By J06GT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2010, 12:27 AM
