Thread: What part is this? Is it required? Billboost help!
Results 1 to 20 of 23
  1. #1 What part is this? Is it required? Billboost help!
    Mar 2012
    Florida
    This is like a temp sensor on the back of the motor. I swapped the motors and did not realize this was missing until I got it all back together and now I cant get this in? What is this and is it required? Thanks kEVIN
  2. #2 Re: What part is this? Is it required? Billboost help!
    Picture or no one knows what you are talking about.
  3. #3 Re: What part is this? Is it required? Billboost help!
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    knock sensor prob... post pic tho
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  4. #4 Re: What part is this? Is it required? Billboost help!
    Only sensor on teh back of the motor that could be an issue is the knock sensor. It's possible. Put a little teflon paste on the threads and in it goes. do what you have to in order to do it. I'm thinking deep socket with a swivel. Torque is 14ft lbs. Too much and you'll read more knock than you should. too loose and you don't read enough.
    Then get that pigtail on it (long needle nose pliers) and smile.. you earned it.
  5. #5 Re: What part is this? Is it required? Billboost help!
    Mar 2012
    Florida
    Billboost, I assume based upon this it is required then correct? I cant seem to find any way to get it up in there now that the motor and tranny is in. Is there a smaller version available?
  6. #6 Re: What part is this? Is it required? Billboost help!
    You can do it. I know that for a fact. There's no smaller. This is your penance for forgetting it.
    You must run it... that's a hole into the water jacket.
  7. #7 Re: What part is this? Is it required? Billboost help!
    Apr 2009
    Fort Worth TX
    Hole is blind IIRC
  8. #8 Re: What part is this? Is it required? Billboost help!
    Portland Oregon
    Quote Originally Posted by Rico View Post
    Hole is blind IIRC
    It's not a blind hole. It goes into the water jacket. Years of dex-cool sludge or sediment make it appear blind until pressure hits it or you tap it with a screwdriver.
  9. #9 Re: What part is this? Is it required? Billboost help!
    you can get to it.
    heres what google picked up...how do u remove bank 2 knock sensor on a 3800 motor - JustAnswer
  10. #10 Re: What part is this? Is it required? Billboost help!
    Apr 2009
    Fort Worth TX
    I see.
    Get it? Blind?
  11. #11 Re: What part is this? Is it required? Billboost help!
    Nope..you aren't skating on this on Chuck. Next time poke that baby with a screwdriver etc and you'll have another gallon of coolant out of the block.
  12. #12 Re: What part is this? Is it required? Billboost help!
    rico your smarter than that.....if you look up from the bottom, between the trans pan and oil pan you can see it clearly, with a extension and socket it can be done.
    i tend to see mine all the time when im cleaning up my oil leaks lol
  13. #13 Re: What part is this? Is it required? Billboost help!
    Apr 2009
    Fort Worth TX
    I was wondering why my block was slowly leaking for a weak after getting it on the stand.
  14. #14 Re: What part is this? Is it required? Billboost help!
    I think Chuck is pulling our legs.
  15. #15 Re: What part is this? Is it required? Billboost help!
    Apr 2009
    Fort Worth TX
    I'm dead serious...didn't know that.
    Oh well.
    I remember feeling up in there and it felt like cast iron blind hole...
    and this was on a block that just came out of the tank!
  16. #16 Re: What part is this? Is it required? Billboost help!
    Next time give her a little poke before tossing it in the tank
  17. #17 Re: What part is this? Is it required? Billboost help!
    Apr 2009
    Fort Worth TX
    Sounds like a plan
  18. #18 Re: What part is this? Is it required? Billboost help!
    Mar 2012
    Florida
    Thanks for all the help here guys. I was able to get it but boy was it tough. I have another question. The exhaust "y: just behind the motor which takes the (2) 10 mm studs. I have the thin metal gasket in there but was wondering if there was a donut gasket or something else that goes in there as well. That metal thin gasket just does not seem like enough. Thanks,
  19. #19 Re: What part is this? Is it required? Billboost help!
    Where it bolts to the catback?
  20. #20 Re: What part is this? Is it required? Billboost help!
    Mar 2012
    Florida
    Yes, I think that is correct. Some people call it the exhaust flange studs
  1. How to pull an engine: BillBoost Style
    By BillBoost37 in forum How To Write-Ups/Tech Tips
    Last Post: 04-12-2020, 04:12 PM
  2. Game: Stump BillBoost Take 2
    By BillBoost37 in forum Off Topic Discussion
    Last Post: 02-10-2013, 11:58 AM
  3. Billboost missing thread lol
    By jteske88 in forum Off Topic Discussion
    Last Post: 07-02-2012, 12:54 PM
  4. Test BillBoost
    Last Post: 07-26-2011, 12:38 PM
  5. I wanna be just like Billboost when I grow up....
    By OH4CompG in forum Off Topic Discussion
    Last Post: 06-10-2011, 11:30 AM
