i went and looked at all the sensors to see if any were visably damaged but they werent and i had the car running. while it was running i heard a tsssssss type sound and i tracked it down to a broken vaccume line. i repaired it with some rubber hoses and the issue that i was having seemed to go away. i also noticed that the vaccume line that was broken caused the egr valve to be stuck open. i am not too sure if this fixed all my issues tho. i took the car out for a ride to test it and see if the acceleration hesitation was gone and it seems to slightly be a bit better but after i hit 50mph at wide open throttle it seems to be slightly hesitant. now could this be caused by the maf sensor being bad or the tps being bad?
