Thread: Car wont start need help!!!!
Results 1 to 12 of 12
  1. #1 Re: Car wont start need help!!!!
    GT Level Member YoungGTP's Avatar
    Aug 2008
    Iowa
    (drums4life if you get your car to start and run i still got the pulley and belt for sale)
    -98 GTP Thunderstorm
    Cai, 3.5 press on pulley, NGK TR6's, 3" to 2.5" exhaust, thrush glasspacks, drilled 180 t-stat soon-overkill pcm, fully ported sc, N* TB, and LQ4 MAF, Future- Full I/C, XP cam, s&s headers
  2. #2 Re: Car wont start need help!!!!
    PA
    I had a similar problem for awhile. It turned out to be a bad shifter cable. The shifter cable, which runs from the shifter in the console, through the firewall, and to the transmission, was binding up inside. I could force the shifter (very hard) into drive. But when I would force it back into park, it would throw off the gear indicator. Then when I went to start next time, it would think it was in R, but was really in Park. I replaced the shifter cable and readjusted the linkage and it has been fine ever since.
    2001 GSE
  3. #3 Re: Car wont start need help!!!!
    sugar land
    i took it to a shop and they siad it had to do something with the tranny. The linkage from the tranny is really stiff. Which i think caused my cable to break or not work as it should. What would cause the tranny linkage to be so stiff??
  1. Car wont start
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 01:57 PM
  2. car rattles after cam install then wont start at all!
    By chrisb in forum General Tech Discussion
    Last Post: 07-11-2008, 10:54 AM
  3. >??? dam still wont start
    By TMOTA503 in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-12-2008, 09:58 PM
  4. Car wont start....mmmm Help!!
    By GeddyLee in forum General Tech Discussion
    Last Post: 02-28-2008, 09:00 PM
  5. Car dead, wont start !!FIXED!!
    By Maybe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2008, 11:27 PM
