Thread: Tune predictions
Results 1 to 9 of 9
  1. #1 Tune predictions
    Nov 2010
    Atlanta Ga
    Put my car on the dyno for a pre tune comparison test. Top swap withVS cam3.4 pulley and ported blower. Made 251 HP and 262 tq.wideband. read 11:9. So how much do you think ill gain from a tune? What ratio do you aim for obviously. Its running a little rich
  2. #2 Re: Tune predictions
    11.9 is lean.
    You want 11.4ish for a boosted car.
  3. #3 Re: Tune predictions
    Banned
    Jun 2012
    Sacramento CA
    11.9 sounds right about perfect for your setup. Is it already tuned? What kind of timing do you see? Any knock?
  4. #4 Re: Tune predictions
    Nov 2010
    Atlanta Ga
    no tune yet. just wanted a before tune example.
  5. #5 Re: Tune predictions
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Well seeing that you're probably getting some knock detonation from the 11.9 a/f and if you go back down to 11.3-11.5 you'd probably pick up some power. Not much. Maybe 5-10 hp. Were you scanning it while on the dyno? Post a graph up?
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  6. #6 Re: Tune predictions
    I wouldnt run the car all out with no "tune", thats sorta like playing with fire.
  7. #7 Re: Tune predictions
    Nov 2010
    Atlanta Ga
    I was trying to sort it out before paying someone to tune. It was pulling timing. It def seemed to get worse when it got hot. I installed a fuel pressure gauge and found the pressure falling as car warmed up. I scoped my fuel pump and found an issue. I replaced the fuel pump and wow what a diff. It went to 281/291 and now my fuel trim is 10:4 at WOT. Now I am going to leave it alone and have it tuned.
  8. #8 Re: Tune predictions
    Quote Originally Posted by fry626 View Post
    Play with an M90 on a high comp bottom end before?
    Dyno at different AFRs?
    Run longevity/durability tests at different AFRs?
  9. #9 Re: Tune predictions
    Nov 2010
    Atlanta Ga
    Im not looking to be bashed or for your opinion on what I do. If it blows up tom. I dont care. Im just having fun. I can get engines all day long. I bought the car with the motor in the trunk. This is how Im learning and having fun at the same time! I was just cur. how much more I could realistically gain from a good tune.
  1. Tune me!
    By crysalis in forum Midwest
    Last Post: 08-06-2011, 01:21 AM
  2. need a tune in az!!
    By Joe m in forum Southwest
    Last Post: 11-03-2010, 11:27 AM
  3. help!14.6@ my tune, 14.4@ stock tune w/genV+
    By Brooks in forum PCM Tuning
    Last Post: 08-16-2010, 06:16 AM
  4. How to get a tune
    By 06grandprix93 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2010, 09:01 PM
  5. Tune up
    By JB381 in forum Engine
    Last Post: 02-22-2010, 06:34 PM
