Thread: Installing Speed Daddy's with motor out - will the huge rear header clear?
Results 1 to 7 of 7
  1. #1 Installing Speed Daddy's with motor out - will the huge rear header clear?
    Cambridge, Ontario Canada
    Rear header is pretty huge, can I drop in motor with front, rear & crossover installed?
    2005 E55 - stock
  2. #2 Re: Installing Speed Daddy's with motor out - will the huge rear header clear?
    Doubt it.
    Just have the rear header laying in the rear of the engine bay tunnel and drop the motor in, then just grab it and install the bolts.
    Front maniold should be okay, but you dont want them all the way tighten because you may have to still wiggle them around to line things up.
  3. #3 Re: Installing Speed Daddy's with motor out - will the huge rear header clear?
    Do you a load leveler? Because then it might be possible.
  4. #4 Re: Installing Speed Daddy's with motor out - will the huge rear header clear?
    Florida
    Yes you can. I did mine with the hood off, and the rear header installed. This was with an el-cheapo cherry picker, no leveler. Just takes a bit of fanagling.
  5. #5 Re: Installing Speed Daddy's with motor out - will the huge rear header clear?
    Exactly the answer i wanted to hear. I popped my hood right off. No leveller either. Camera ready!
    2005 E55 - stock
  6. #6 Re: Installing Speed Daddy's with motor out - will the huge rear header clear?
    Florida
    Do it! I ended up having to remove the battery tray in order to get just enough clearance for the crank pulley. If it looks like the engine is going in at too much of an angle (either up/down, or sideways) it probably hasn't gone far enough. The front header wasn't on the engine either. Also, all done with just me, no one to help. Good luck.
  7. #7 Re: Installing Speed Daddy's with motor out - will the huge rear header clear?
    Antioch, IL
    I did it with the front installed, but not the rear, wasnt gonna take off my hood, I just had the struts taken off. I had to take the front off anyway to get the dam crossover on the front.
    2009 Challenger SRT8
    Expert at being gay.
  1. Couple of specific speed daddy header quesions
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2012, 08:00 AM
  2. Speed daddy header egr issue
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2011, 05:47 PM
  3. Speed Daddy Header install writeup
    By vailskier3 in forum General Tech Discussion
    Last Post: 10-26-2011, 09:28 AM
  4. speed daddy s/c or not
    By GOINDEF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-23-2011, 07:47 PM
  5. HUD Stopped Working After Huge Speed Bump
    By AmericaFcukYeah in forum General Tech Discussion
    Last Post: 05-24-2008, 12:13 PM
