Thread: are these the right spark plugs i need?
Results 1 to 7 of 7
  1. #1 are these the right spark plugs i need?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    i have a stock 97 gtp with and intake and thats it.
    are these the right plugs i need. AutoLite Copper Core Spark Plugs (3 heat ranges): 3800 Performance the 605's right?
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: are these the right spark plugs i need?
    St. Louis
    Looks about right according to the safely modding thread...
    4)
    Spark Plugs - Change out those stock spark plugs with new ones to restore any lost power. Brands that most tend to go with are either Copper Core Autolites or NGK Spark Plugs. Get these at your local auto parts store also. They range as follows in order from hottest to coldest plugs...remember...you want the hottest spark possible...so running a super cold plug on a larger pulley to combat knock isn't the best plan...ACD's, AL606's, and AL605's are basically for stock cars or very small bolt ons still running the stock S/C Pulley or modded N/A guys...you want to keep a hot spark. NGKTR55/AL104's for your 3.4" Setup, TR6's are a tad cooler...best used around the 3.25" pulley area, and AL103's...are for the extreme supercharged application...3.0" pulley or lower. Here is a picture to reference the firing order and the correct coil number if yours aren't numbered or you just need a quick reference picture: http://i33.photobucket.com/albums/d6.../plugwires.jpg
    AC Delco Factory Replacements: Stock
    Autolite 606: Stock
    Autolite 605: 1 Heat Range Cooler
    NGK TR55: 1 Heat Range Cooler
    Autolite 104: 2 Heat Ranges Cooler
    NGK TR6: 2 Heat Ranges Cooler
    Autolite 103: 3 Heat Rangles Cooler
  3. #3 Re: are these the right spark plugs i need?
    I would still get the 606s IMHO
  4. #4 Re: are these the right spark plugs i need?
  5. #5 Re: are these the right spark plugs i need?
    Sep 2011
    palm harbor florida
    606's gapped at ?
  6. #6 Re: are these the right spark plugs i need?
  7. #7 Re: are these the right spark plugs i need?
    Sep 2011
    palm harbor florida
    ok thanks everyone
  1. Spark Plugs on '04
    By 04GT2 in forum General Tech Discussion
    Last Post: 08-10-2016, 12:34 PM
  2. Replies: 34
    Last Post: 05-28-2012, 10:53 AM
  3. spark plugs
    By gtpdriver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-04-2011, 01:22 PM
  4. Spark plugs
    By Chleby in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-16-2009, 10:43 PM
  5. Spark Plugs
    By adidasdude1061 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2008, 10:45 PM
