Thread: Large EVAP LEAK and FUEL CAP LEAKING?????
Results 1 to 9 of 9
  1. #1 Re: Large EVAP LEAK and FUEL CAP LEAKING?????
    Oklahoma
    Well the gas cap certainly isnt going to cost you $40 at Autozone. As for the Evap vent valve, I dont even know where thats at, so I'll be no help there. For the sake of arguement, however, I would replace the cap first then see what you get, the gas cap could be all there is to it.
  2. #2 Re: Large EVAP LEAK and FUEL CAP LEAKING?????
    TDCRacing
    Guest
    The only thing that i know of that would cost that much that is related to the evap system would be the EVAP purge valve. Wich is basicly a small air pump. If this is your problem it's about a 10 minute change. Then again it may be something in the gas tank....wich would lead to the labor charges...but then agin book time can be way off on little things like this...Wonder how much labor they charge for the gas cap
  1. diagnosing fuel leak
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2008, 03:27 AM
  2. fuel leak
    Last Post: 08-18-2008, 03:40 PM
  3. HELP! FP leak at large quick disconnect!?!
    By alacran in forum General Tech Discussion
    Last Post: 07-24-2008, 01:01 PM
  4. Deleting the EVAP
    By Andrew_99GTP in forum General Tech Discussion
    Last Post: 06-16-2008, 09:39 AM
  5. fuel line leaking
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-15-2008, 03:08 AM
