Thread: 2001 gtp question on what this sound could be
Results 1 to 11 of 11
samuelcb409 2001 gtp question on what... 07-17-2012, 03:42 PM
Scottydoggs Re: 2001 gtp question on what... 07-17-2012, 03:52 PM
samuelcb409 Re: 2001 gtp question on what... 07-17-2012, 06:42 PM
Scottydoggs Re: 2001 gtp question on what... 07-17-2012, 07:41 PM
samuelcb409 Re: 2001 gtp question on what... 07-18-2012, 02:38 PM
Scottydoggs Re: 2001 gtp question on what... 07-18-2012, 03:02 PM
samuelcb409 Re: 2001 gtp question on what... 07-19-2012, 01:21 AM
FordMan77 Re: 2001 gtp question on what... 07-19-2012, 10:31 AM
blueguy Re: 2001 gtp question on what... 07-19-2012, 11:33 AM
Scottydoggs Re: 2001 gtp question on what... 07-19-2012, 11:34 AM
blueguy Re: 2001 gtp question on what... 07-19-2012, 11:45 AM
  1. #1 2001 gtp question on what this sound could be
    SE Level Member samuelcb409's Avatar
    Galveston, Texas
    Car started doing this last night after i got it retuned and was driving home, on the highway car in front of me hit a piece of tire and had no way to avoid it at like 75-80mph it hit under the car.. so when i got home i noticed the sound when had the windows down parking the car. any thoughts on what it could be?
    MODS: 3.0 MPS, CAI, SD Headers w/Custom 3"DP, 160* T-Stat, NGK TR6, Full Size intercooler, #42.5s, Ported LIM & Gen III, LS1 TB w/85mm MAF , s1x Cam, #90 Springs, Intense Pushrods, EGR Delete, Cat and U Bend Delete, Magnaflow Resonator & Mufflers, Fully Built ZZP Trans, 2800 stall Tuned by KHP Peformance
  2. #2 Re: 2001 gtp question on what this sound could be
    check the plastic inspection plate under the trans, by the oil pan's square side, it could be smashed into the flex plate.
  3. #3 Re: 2001 gtp question on what this sound could be
    Galveston, Texas
    Gotta get a jack but from what I can see the oil pan has a kind of well sized dent could that cause that
  4. #4 Re: 2001 gtp question on what this sound could be
    that sounded like plastic to me, but hey it could be the crank hitting the oil pan.
    depending on the size and where the dent is you may, and i do mean may be able to pull it with a toilet plunger, the kind thats a real suction cup at the end. or a small one, hard to find but i have seen them.
    make it stick to the pan and pull it off hard and fast. this works well for dented doors and such, the pan is thicker and this may not work.
    could even try to glue a something to the pan and pull the dent if the plunger dont work. like epoxy something you can pull on to the pan.
    or get a new pan, not all that easy to change.
    but do check out the inspection shield.
  5. #5 Re: 2001 gtp question on what this sound could be
    Galveston, Texas
    checked under but aint see no inspection shield there at all is the flex plate always visible from under or did that cover it cause i can see it and sound it coming from @ that area by the torque converter/flex plate i can hear it slightly as motor idles from under the car so i unsure what this is hopefully nothing major
  6. #6 Re: 2001 gtp question on what this sound could be
    no you should have a plastic shield there so that the flex and torque converter are covered up.
    get a flash light and see if it got mashed up into the bell housing or a piece of it.
  7. #7 Re: 2001 gtp question on what this sound could be
    Galveston, Texas
    it wasnt never there i dont think when trans was installed, any chance the trans filter maybe would have fell off during the impact from the tire cause i was told to check that cause earlier i tried to drive the car and the noise was still there then started getting issues taking off from stop light, then when i got home would not reverse so... i was told that could be the issue that the fluid isnt rotating through the filter and starved of fluid it would stop going... so after few hours tried to start the car and then it was able to reverse but the noise was still..
  8. #8 Re: 2001 gtp question on what this sound could be
    St. Louis
    Possible if it hit it hard enough, but I would think it would dent the living daylights out of the transmission pan to do that seeing as how the filter stays in place during normal driving which has just as many bumps and vibrations along the way.
  9. #9 Re: 2001 gtp question on what this sound could be
    WURz TEH PICtars.
    Also, it could be something related to the accessory drive...think pulley, tensioner, etc.
  10. #10 Re: 2001 gtp question on what this sound could be
    yeah like the splash shield hitting the balancer.
  11. #11 Re: 2001 gtp question on what this sound could be
    Yeah, that's why I ripped all that bullcrap off.
    Who cares about a little road grime...if you clean your car often you don't have to worry about it.
  1. Summit Racing headers & best sound question
    By GTLGDP in forum General Tech Discussion
    Last Post: 12-17-2011, 08:17 PM
  2. 2001 Transmission question
    By solidsnake1972 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2011, 06:20 AM
  3. exhaust sound question
    By killakross5o4 in forum Off Topic Discussion
    Last Post: 03-14-2010, 01:25 PM
  4. 1995 GTP premium sound question
    By Adabow in forum Audio, Security & Visual Electronics
    Last Post: 08-31-2009, 11:34 PM
  5. 2001 Grand Prix - Supercharger Question
    By nmaponte in forum Introductions/Noob Questions
    Last Post: 03-14-2009, 11:53 AM
