Thread: LIM job just finished & still ticking!! VIDEO & Help! **UPDATED July 19**
Results 1 to 20 of 36
  1. #1 LIM job just finished & still ticking!! VIDEO & Help! **UPDATED July 19**
    Cambridge, Ontario Canada
    POS POS, just finished the LIM job took me 2 weeks because I am extremely busy. Last GTP had the same ticking noise, I did the LIM job and the tick went away. This new POS got the LIM job and the tick remains. I pulled off supercharger blet no change, pulled eash of the front injectors no change. Put a screwdriver everywhere but can't seem to hear anything quite as loud... Oil colour is pristine and no signs of anything in the oil.
    I got no time to deal with this crap & need a car.
    Video below:
    Opinions please?
    Lucas Oil Stabilizer?
    2005 E55 - stock
  2. #2 Re: LIM job just finished & still ticking!! VIDEO & Help!
    Jun 2012
    Hammond,in
    Just my 2cents...... sounds like a lifter!
  3. #3 Re: LIM job just finished & still ticking!! VIDEO & Help!
    Indianapolis, Indiana, United States
    Bent push rod? Bent valve?
    “I don't mind living in a man's world, as long as I can be a woman in it.”
    -Marilyn Monroe<3
  4. #4 Re: LIM job just finished & still ticking!! VIDEO & Help!
    put some seafoam in the oil and if it goes away then change the oil out and put lucas oil stabalizer in it.
  5. #5 Re: LIM job just finished & still ticking!! VIDEO & Help!
    GT Level Member 98GPGT2D's Avatar
    Ontario, Canada
    Get some seafoam or a quart of transmission fluid put into the engine oil and let it run. Sounds like you have a lifter gone bad. Would have been a simple job to replace them while the lower intake was off...
    but yea, get some seafoam or trans fluid in your oil. It will act as a detergent and hopefully clean the collapsed lifter and allow it to pump up.
    Jay
    2005 GMC Jimmy 4x4 2-door 5-speed. CompCams 266HR Cam, W4M tune, 2.5" Exh, 246,000Kms (Sept 2012) Daily Driver.
    2002 Yamaha YZ125, Summer Toy.
    1997 GrandPrix GT 4 door White Ext, Pleather Int. 255,000Kms GF's Daily Driver.
  6. #6 Re: LIM job just finished & still ticking!! VIDEO & Help!
    Feb 2008
    I also think you should put a bottle of seafoam into your oil - run the car for about 100 miles, 150 at most and change the oil. It could be a lifter.
  7. #7 Re: LIM job just finished & still ticking!! VIDEO & Help!
    id listen close for witch side the noise is coming from, front or back, and then pull the valve cover and see whats what.
    that defiantly sounds like rocker clap, due to bent push rod or a dead lifter.try some 40 weight oil, it may fix it up. but worth looking at.
    take the cover off and run the engine, if you spin the push rods you should be able to tell if its bent or not, and should see the rocker making the noise, grab it while its running it will be loose.
  8. #8 Re: LIM job just finished & still ticking!! VIDEO & Help!
    GTX Level Member crbquist's Avatar
    Massachusetts
    Wow, that sucks
    01 Silvermist GTP - E85 - Cam - Heads - Phenolic IC - Polished Gen V - Stock trans...
  9. #9 Re: LIM job just finished & still ticking!! VIDEO & Help!
    For starters I am going to pull the valve covers & have a look. If nothing visible, then going to swap oil to 10W40, grab some seafoam & wait till night time then smoke out the district. If that still doesn't work I will pull the valve covers again, remove rockers and pushrods to look for problems. If that still doesn't work then into the motor again I guess to replace lifters...
    Is this the correct approach?
    2005 E55 - stock
  10. #10 Re: LIM job just finished & still ticking!! VIDEO & Help!
    they sell cheap mecanics stethoscopes for about 10 bucks or less, id get one and play Dr. first, then pull the cover with the noise.
  11. #11 Re: LIM job just finished & still ticking!! VIDEO & Help!
    Tried that yesterday with a screwdriver, couldn't really hear a big difference between the banks. Injectors were making lots of noise using that method in comparison to placing the driver on the valve cover. Will see about getting one tonight.
    2005 E55 - stock
  12. #12 Re: LIM job just finished & still ticking!! VIDEO & Help!
    I think the way your wanting to approach it sounds good let us know what you find out..... And Good luck!
    -Marilyn Monroe<3
  13. #13 Re: LIM job just finished & still ticking!! VIDEO & Help!
    So your going to pull the valve covers two times? Why not pull it once..check rocker and pushrods make sure they're tighten to specs and not bent. start the car if noise persist then possible change oil and or inspect lifters?
    04 Comp G.
  14. #14 Re: LIM job just finished & still ticking!! VIDEO & Help!
    I am somewhat more sure that the noise is coming from the rear bank and kinda below the lim. I am going to seafoam tonight. If that is a fail then pull everything out again except the sc and lim. Inspect rockers and pushrods the with valve covers off.
    2005 E55 - stock
  15. #15 Re: LIM job just finished & still ticking!! VIDEO & Help!
    I am not sure you can pull the rear valve covers with all that bull**** back there and be able to start car?
    2005 E55 - stock
  16. #16 Re: LIM job just finished & still ticking!! VIDEO & Help!
    you can run it, just hook up the vac lines and the sensor back there after you take the cover off, leave the alt to the side but hooked up. i think the red power line needs to be hooked up or the car wont start up. like no crank maybe.
  17. #17 Re: LIM job just finished & still ticking!! VIDEO & Help!
    Mar 2012
    lakewood
    why not get a feeler gauge and manually check the each rocker.
  18. #18 Re: LIM job just finished & still ticking!! VIDEO & Help!
    Mar 2012
    lakewood
    one of them is not like the others
  19. #19 Re: LIM job just finished & still ticking!! VIDEO & Help!
    Sea foam failed.... Tomorrow will pull valve covers and have a look. More vids to come
    2005 E55 - stock
  20. #20 Re: LIM job just finished & still ticking!! VIDEO & Help!
    Well this sucks, looks like I have to drain coolant again to get rear valve cover off, as the alternator bracket needs to come off.
    2005 E55 - stock
  1. Ticking noise or am i losing my mind? (video)
    By GTLGDP in forum General Tech Discussion
    Last Post: 03-09-2012, 10:21 PM
  2. Something ticking (Video)
    By fri3dchick3n in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2011, 01:45 AM
  3. Finished!!
    By blueguy in forum Off Topic Discussion
    Last Post: 04-03-2009, 03:17 AM
  4. Im finished, its over with, Im done
    Last Post: 02-21-2009, 10:35 PM
  5. My New, Actually Of The GTP, Video (Finished!)
    Last Post: 11-06-2008, 03:14 PM
