Thread: Oil Pressure readings?
Results 1 to 11 of 11
  1. #1 Oil Pressure readings?
    Jun 2012
    Grantville, Ga
    I am wonderng what the normal oil pressure readings you all see with manual gauges? I have notices mine droped some whitch has me concerned. At idle its 15 psi and driveing a operating temp, 2000 rpm it at 35 to 39 psi. Trying to find out what my next step is ging to be.
    Thanks
  2. #2 Re: Oil Pressure readings?
    Depending on your climate and choice of oil and filter... there will be variances.
    Typically I'd say 30-40 for idle and 40-50+ for 2000 rpm
  3. #3 Re: Oil Pressure readings?
    if your motor is well worn, you might only see 15-25 at idle.
  4. #4 Re: Oil Pressure readings?
    Jun 2012
    Grantville, Ga
    Fresh rebuild, new bearings and riings. I will be changing oil today to 15-40 since its been 100+ here. 5-30 i think is to thin so i will do that later today.
  5. #5 Re: Oil Pressure readings?
    i always ran 10w-40.
    recommended is usually 10w-30, but the 40 weight helps keep pressures up higher where you'd like them.
  6. #6 Re: Oil Pressure readings?
    Easy way to bhump the pressure a little bit is to also buy the '04+ accumulator/spring kit for the oil filter housing.
    Easily good for a 5~+ PSI bump.
  7. #7 Re: Oil Pressure readings?
    I see 70 psi at start up (cold). HOT idle is 35-40 and always at 60-65 while crusing around town and on the freeway when the rpms are at 2,000 to 2,500.
    And I would not run 15w40, 10w30 or 10w40 will do fine.
  8. #8 Re: Oil Pressure readings?
    20W-50, like a boss.
  9. #9 Re: Oil Pressure readings?
    St. Louis
    According to my Sport-Comp gauge and 130K on a used motor I see 75 at cold startup, 49-50 at hot idle in gear (stoplight), and 74 crusing on highway at 60 (~2K rpms). About 70 when crusing city areas. This was as of today with 104* temps outside and the A/C on. I always run conventional 10W-30 Valvoline in it with a Wix filter just like all my other cars minus my 03 CV.
    I do happen to run Valvoline VR-1 20W-50 in my 74 Midget, like a boss, lol...
  10. #10 Re: Oil Pressure readings?
    Grand Island, Nebraska
    I have about the same as this guy^
  11. #11 Re: Oil Pressure readings?
    SE Level Member RedGrandprixgt53's Avatar
    Oct 2011
    Kenosha, WI
    i see about 80 at idle cold. then once it warms up im around 60-70 cruising and just above 50ish warm idle
  1. Can someone look at these readings and let me know if anything is out of whack?
    By silver86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2012, 02:33 PM
  2. Oil pressure readings/misc others 00 GT
    By FordMan77 in forum General Tech Discussion
    Last Post: 05-16-2011, 07:32 AM
  3. what are the proper oil pressure readings
    By Scottydoggs in forum General Tech Discussion
    Last Post: 09-02-2010, 06:11 PM
  4. O2 readings
    By Silver GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-28-2010, 10:44 PM
  5. O2 readings
    By Progas in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-08-2008, 02:24 PM
