Thread: SC Oil Leak...
Results 1 to 5 of 5
  1. #1 SC Oil Leak...
    Donating Users 1quikgp's Avatar
    Jan 2009
    Ohio
    I'm getting ready to do a coupler change so I removed the sc belt to run some errands. I noticed a foul smell, when I popped the hood there was sc oil everywhere. I never noticed a leak before removing the belt. Is this normal or is the snout seal shot?
  2. #2 Re: SC Oil Leak...
    if its leaking from the snout, then yes.
  3. #3 Re: SC Oil Leak...
    Leaking at the very end of the snout or up where it bolts to the rest of the sc?
  4. #4 Re: SC Oil Leak...
    Jan 2009
    Ohio
    On the pulley end dripping down on the belt, I was just curious since it wasn't leaking before I removed the belt.
  5. #5 Re: SC Oil Leak...
    Jan 2009
    Ohio
    Oil is coming out of the breather hole not the seal. Not sure why... I'll just ordered a new snout and be done with it!
  1. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  2. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  5. oil leak on 3.4 dohc. Not that oil leak.
    By 67GTO in forum General Tech Discussion
    Last Post: 06-14-2010, 11:52 AM
