Thread: Difference in 97-03 and 04+ catback exhaust?
Results 1 to 8 of 8
  1. #1 Difference in 97-03 and 04+ catback exhaust?
    Jun 2012
    Pennsylvania
    Hello Folks,
    Hopefully a GP owner can answer this. In looking at the cat-back systems offered by ZZP, there are two selections, one for the 97-03 GP and then the 04+ GP. What exactly is the difference between the two systems? I'm going to order one of the other for the Impala, and even though it's an 04, the body for the Imp didn't change till 06, instead of the GP in 04. I'm thinking I should get the 97-03 set, but am just not sure. My best guess is length, but I'm not sure.
    Loud
  2. #2 Re: Difference in 97-03 and 04+ catback exhaust?
    Buy 2 mufflers, drive to exhaust shop, weld them on with tips.
    I just saved you a few hundred bucks.
    Catbacks are dumb unless yours is completely rusted away and has fallen out from under the car.
    Also, ZZP mufflers may drone just like flowmaster and magnaflows.
  3. #3 Re: Difference in 97-03 and 04+ catback exhaust?
    Jun 2012
    Pennsylvania
    I was going to go that route, but due to rust, I need new. The inspection tech told me that my car would probably fail inspection next year unless I replace it.
    Loud
  4. #4 Re: Difference in 97-03 and 04+ catback exhaust?
    Apr 2012
    Manorville, Ny
    im planning on buying there full 3" exhaust in a couple days for my 98 gtp, mines not rusted out quite yet but i dont want the reasonator cause i want it to be a little louder and the 3" down pipe, i dont want to weld it in cause a shop would charge a fourtune i bet. so the full system is 530, compared to 350 for the mufflers and 3" down pipe.
    by the way how big is the exhaust stock?
    1998 Grand Prix Gtp 4 Door.
    Team Li SPL
  5. #5 Re: Difference in 97-03 and 04+ catback exhaust?
    To answer your question..the location of the exhaust hangers is what's different. Any exhaust shop can fix this.
    04 Comp G.
  6. #6 Re: Difference in 97-03 and 04+ catback exhaust?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    2.25 inch i think.
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  7. #7 Re: Difference in 97-03 and 04+ catback exhaust?
    Portland Oregon
    I ran a GTP catback on my Impala. You'll need to extend the tips by about 6-8 inches. The Imp bumper hangs out further
  8. #8 Re: Difference in 97-03 and 04+ catback exhaust?
    2.25ish to the Y, then its split into two 1 7/8 size pipes to the mufflers.
