Thread: oil pan drop
Results 1 to 19 of 19
  1. #1 Re: oil pan drop
    Guess I've just been under enough leakers. The dye usually isn't needed for me to see them, because of how badly they leak. If I hop under and look up with a light, I can see the wetness coming down the block. That's valve covers. If just the edge of the pan and maybe an inch up is wet..that's pan or rear cover typically.
  2. #2 Re: oil pan drop
    Denver
    Knowing what I know now, I would not use the dye. It's a gimmick that helps, but it's easy to find without the dye. All you need is a clean block and a paper towel.
  1. Sudden Drop in MPG
    By Steel Armadillo in forum Engine
    Last Post: 11-06-2011, 11:42 PM
  2. MPG Drop
    By 2k6GT in forum General Tech Discussion
    Last Post: 08-14-2009, 11:56 PM
  3. ready to drop in!
    By mikedinthecity in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-05-2009, 02:19 AM
