Thread: S/C Belt issues?!
Results 1 to 11 of 11
Bogers04SS S/C Belt issues?! 06-27-2012, 05:12 PM
KeithGTP03 Re: S/C Belt issues?! 06-27-2012, 06:31 PM
Bogers04SS Re: S/C Belt issues?! 06-27-2012, 10:32 PM
Bio248 Re: S/C Belt issues?! 06-28-2012, 08:15 AM
KeithGTP03 Re: S/C Belt issues?! 06-28-2012, 12:02 PM
Mjcanton Re: S/C Belt issues?! 06-29-2012, 05:31 PM
Bogers04SS Re: S/C Belt issues?! 07-01-2012, 01:18 PM
Mjcanton Re: S/C Belt issues?! 07-01-2012, 02:01 PM
stealthee Re: S/C Belt issues?! 07-01-2012, 01:39 PM
Bogers04SS Re: S/C Belt issues?! 07-01-2012, 02:01 PM
Bogers04SS Re: S/C Belt issues?! 07-02-2012, 01:20 PM
  1. #1 S/C Belt issues?!
    GT Level Member Bogers04SS's Avatar
    Feb 2010
    Mocksville, N.C.
    I recently ported my blower and put everything back on, but the other day it threw a belt off going down the road. Went to Advance auto, got a new belt only to get home and the dang thing wont fit! It's the factory belt i've used on my 3.5 setup with the 3.5 tensioner pulley, but now it seems its not long enough. What could be the issue?! The factory belt was a Dayco 665.
    04 Impala SS -- SOLD
    08 Prix GXP -- FWI, 3in DP, TR6IX plugs, Ported & polished throttle body, ported intake manifold, DiabLEW Tuned, wrapped crossover pipe, Cat delete, Factory res., Muffler delete, Poly motor mounts, shift kit, LED bulbs in just about every Da*n thing, ect..
  2. #2 Re: S/C Belt issues?!
    Houston
    You sure its routed correctly?
  3. #3 Re: S/C Belt issues?!
    Feb 2010
    Mocksville, N.C.
    Mine doesn't quite look like the diagram. According to diagrams I've looked at, it shows me the way I ran it.
  4. #4 Re: S/C Belt issues?!
  5. #5 Re: S/C Belt issues?!
    Houston
    The last pic was the supercharger belt diagram. Here is both:
  6. #6 Re: S/C Belt issues?!
    Feb 2008
    That's a pretty good image, I've never been able to find one that good!
  7. #7 Re: S/C Belt issues?!
    Feb 2010
    Mocksville, N.C.
    Well, the belt I got was too short (mind you it had 665 on the label). took it to autozone and compaired and it was shorter then it should have been. So now the belt fits, but its burning up the belt (rubber in the grooves of the S/C pulley and grooved idler pulley). I took both the 3.5 idler pulley and the grooved pulley off to see if thet were seized. The 3.5 idler pulley was shot and so was the grooved idler pulley. Would this be the cause of it eating the belt up and causing it to "walk" off of the crankshaft pulley?
  8. #8 Re: S/C Belt issues?!
    Feb 2008
    Quote Originally Posted by Bogers04SS View Post
    Definitely. If the pulley isn't moving you're going to have some problems. They are easy to replace though.
  9. #9 Re: S/C Belt issues?!
    SWPA
    If the idler is siezed then yes that can cause belt issues. Thats basic common sense.
  10. #10 Re: S/C Belt issues?!
    Feb 2010
    Mocksville, N.C.
    I replaced the 3.5 idler pulley, now to head to the local junk yard where a freshly wrecked GTP is sitting. Gonna grab the gooved pulley off of it. I do have one question.... On the back of the grooved idler pulley, is there a plate, washer or something that keeps you from over tightening it to the block itself?
  11. #11 Re: S/C Belt issues?!
    Feb 2010
    Mocksville, N.C.
    Here is that I mean by this...
    I saw on the GTP and GS that was in the junkyard yesterday that there seems to be a machined peice on the block for the pulley to go against. As you can see from the pics above, there isnt anything on my SS?
  1. 3.6 do I need a new belt?
    By chevyy1212 in forum General Tech Discussion
    Last Post: 10-25-2011, 02:38 PM
  2. Size wrench needed to adjust belt tensioner for accessory belt install?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-03-2011, 09:29 PM
  3. can you run the car without the SC belt?
    By 97RS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2011, 10:09 AM
  4. 3.4 belt
    By xsvtank in forum General Tech Discussion
    Last Post: 05-31-2010, 12:27 PM
  5. seat belt ?
    By crewsn in forum General Tech Discussion
    Last Post: 04-17-2009, 10:19 PM
