Thread: Grand Prix build looking for help
Results 1 to 8 of 8
  1. #1 Grand Prix build looking for help
    Jun 2012
    alabama
    Im looking to build a 2004 Grand Prix GTP have done some looking and this seams to be the normal build just looking for some input. Should I go SS intercooler or full sized what hood will the full sized fit under. What size pulley. Thanks in advance.
    Intercooler
    Smaller pulley
    Auto light 104 plugs
    Zzp 1.0 pcm
    180 thermostat
    intake
    exhaust
  2. #2 Re: Grand Prix build looking for help
    North Jersey
    all that...
    depends on your budget and what you want to do with your car.
  3. #3 Re: Grand Prix build looking for help
    Jun 2012
    alabama
    helping a buddy he wants to run an 1/8 mile but will be daily driving this car also
  4. #4 Re: Grand Prix build looking for help
    Um, yeah, a canned tune cant be run with a intercooler.
    You need a full on custom tune with a wideband.
    Headers, Intake, 605's, 3.6 pulley and a overkill tune will do fine.
    Anything past a 3.6 and you dont want to run a canned tune, it only good for so much.
    (I say 3.6 because the Gen V is better than a Gen 3)
    You got alot of reading to do, to know how to mod these cars.
  5. #5 Re: Grand Prix build looking for help
    Also, after adding that power, the trans becomes weaker and will be the weak point.
  6. #6 Re: Grand Prix build looking for help
    Texas
    Do not I repeat do NOT go with a SS intercooler. Complete waste of money. I did it on a previous GTP and regretted it later.
    85 Corvette
    01 TA
    03 Z06
  7. #7 Re: Grand Prix build looking for help
    Kemmerer, Wyoming
    an intercooler is good but you could also do a cam or roller rockers.
  8. #8 Re: Grand Prix build looking for help
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    dont so a SS IC bad idea, put a full sized IC on there get a MPS and run a 3.5'' or 3.4'' pulley withe some headers also make your own intake, the correct plugs and a 180 tstat too, you should be able to fit the IC with the stock hood unless you lower your car, you might need bigger injectors too, top it all off with a custom dyno tune from a local shop and you should be good to go until you break your trans
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  1. 00' Grand Prix GTP (Build starting)
    By Stinkygrub in forum Members Rides
    Last Post: 04-09-2012, 10:48 AM
  2. Grand prix + circle track build = this?
    By Wotgtp in forum Off Topic Discussion
    Last Post: 09-25-2011, 04:48 PM
  3. 2000 Pontiac Grand Prix GT Transmission Re-Build Necessary?
    By gates1847 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-25-2011, 10:55 AM
  4. My Grand Prix Build..
    By Lethaface in forum Off Topic Discussion
    Last Post: 04-14-2009, 12:58 AM
  5. Grand Prix Build Up on CarDomain...
    By Iron Indian in forum Visual/Body Modifications
    Last Post: 10-14-2008, 06:59 PM
