Thread: Engine cover removel?!?
Page 1 of 3 123 LastLast
Results 1 to 20 of 54
  1. #1 Engine cover removel?!?
    May 2012
    Thunder Bay, Ontario, Canada
    How the heck do I take off the plastic cover that is on top of the motor but under the oil spout, 2007 Pontiac grand prix gt
    Anyone know or have a video as to how to do this?
    pontiac engine cover - Google Search
  2. #2 Re: Engine cover removel?!?
    Apr 2009
    Fort Worth TX
    Twist oil spout to left and remove it.
  3. #3 Re: Engine cover removel?!?
    May 2012
    Are you sure because it looks to be apart of a plastic valve covering bolted to the block underneath
  4. #4 Re: Engine cover removel?!?
    Apr 2009
    Fort Worth TX
    Ask yourself this, "how would I remove the front valve cover if I can't remove the engine cover?".
    Answer: You can remove the engine cover by twisting the oil spout to the left.
  5. #5 Re: Engine cover removel?!?
    SWPA
    Quote Originally Posted by 2007GrandPrixGT View Post
    Why ask the answer to a question you don't know, then question the answer someone gives you who has been on the forum for over 3 years?
    His answer is correct. Hell I figured out how to take the cover off in 5 seconds., and I did it without asking here.
  6. #6 Re: Engine cover removel?!?
  7. #7 Re: Engine cover removel?!?
    May 2008
    Winnipeg, MB
    If you have to ask this question, please never open the hood again. Leave things to the professionals.
    2007 Pontiac Grand Prix
  8. #8 Re: Engine cover removel?!?
    I had to use a sawzall to get mine off oil caps are so tricky.
  9. #9 Re: Engine cover removel?!?
    Apr 2012
    Bancroft. Ontario, Canada
    It also took me 50seconds to pull mine off....
    I vote this thread be closed
  10. #10 Re: Engine cover removel?!?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Never know when this question will come up again. Do we need it stickyed ? lol
    1997 Red GTP 182000 miles stock
  11. #11 Re: Engine cover removel?!?
    SWPA
    No one pays attention to stickys, so its probably best to not sticky it, then the vast amount of knowledge in this thread will be more likely to be seen by hundreds, if not thousands.
  12. #12 Re: Engine cover removel?!?
    Apr 2009
    Fort Worth TX
    no one pays attention to stickys, so its probably best to not sticky it, then the vast amount of knowledge in this thread will be more likely to be seen by hundreds, if not thousands.
    Now you're just being a wise-arse.
  13. #13 Re: Engine cover removel?!?
    GTP Level Member
    Oct 2011
    Raleigh, NC
    I figured it out without asking, so anyone should be able to. Some people just don't step back and access what they are trying to do.
  14. #14 Re: Engine cover removel?!?
    Feb 2010
    TN
    Wrap a chain around the cover, attach the other end to a tree rev it up throw in in reverse, job done, and now its Miller time
  15. #15 Re: Engine cover removel?!?
    Mar 2012
    lakewood
    But if you took the oil cap off how would you get it back on?
  16. #16 Re: Engine cover removel?!?
    Quote Originally Posted by thomas mcnulty View Post
    copper rtv
  17. #17 Re: Engine cover removel?!?
    Out West
    burn a new one on there.
    Whine with your Cheese?
  18. #18 Re: Engine cover removel?!?
    michigan
    Dont close this thread.....its questions like these that make me feel like a freakin genius!!!
  19. #19 Re: Engine cover removel?!?
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    This thread is just all full of winning
  20. #20 Re: Engine cover removel?!?
    Florida
    reminds me of the blond who was looking for a 710 cap... and for those who dont get it OIL = 710 upside down.
    we can add this thread to rotating the air in your tires and refilling your headlight fluid.
  1. new engine cover, braces n fusebox cover
    By beckys2000gt in forum Visual/Body Modifications
    Last Post: 05-27-2010, 09:40 AM
  2. $50 engine cover
    By nemesis in forum Off Topic Discussion
    Last Post: 04-10-2010, 08:49 PM
