A lot of the misconceptions about the Series II is carry-over from the Series I.
For instance:
"You have to pack the gerotor with petro grease for the Series II to prime".
ANK- Wrong
Fill it with oil and let sit for 10 minutes.
Crank engine for 20 seconds or so without ignition until oil pressure gauge deflects.
For me, oil gerotor primed within about 5 seconds of cranking on both engines I rebuilt.
Plug ICM in and start motor - done - 20psi + at idle cold
The Series I may not prime without packing the gerotor.
"You have to machine connecting rods when using ARP bolts"
ANK- Wrong
When I read this on ZZP's website I was utterly confused.
I thought the rod needed to be machined relative to the bolt.
They actually meant resizing.
A good bore gauge or micrometer will do amazing things for you.
If the bore is in spec and not OOR then it doesn't need machined.
How crazy is that? Not crazy at all to an engine builder or machinist.
Why spend the money machining something that is already in spec? IDK
Out of the 24 rods I recently checked only 2 were more than 0.0004" OOR.
For clarification that is 4/10th's of 1/1000th of an inch.
For an all out race motor you may want it to be < or = to 2/10th's of 1/1000th of an inch.
2/10th's would require CNC resizing and hand honing - it's expensive.
"You have to align hone the mains when rebuilding the Series II"
Really?
ANK - Wrong
Check to see if it needs align honed.
Again, micrometers are your friend so check for OOR.
Alignment? EASY
Bolt up the heads with a set of old head gaskets and torque them down.
Check main bearing to crank clearances.
If the clearances are good and the crank spins freely then VIOLA.
If it's out of spec then take it to the scrap yard and get a few bucks for it.
The Series I is known for twisting the block - misaligning the mains.
GM made many structural improvements to the Series II.
Series II main misalignment is not nearly as common as everyone thinks.
I know that much of the above is overwhelming but it's much easier than installing a head unit and wiring up the steering wheel controls.
IMHO what kills these engines is the "budget rebuild" and the crankshaft is usually the culprit. The clearance specs on the 3800 are so tight that the crank has to be perfectly straight and the journals have to be smooth as a baby's bottom. If we do what we're supposed to, rebuilding the 3800 is a breeze!!!
Matt
I'm on my third engine and the first two have 7K and 19K on them respectively. I'll let you know when they blow up. LOL
