Thread: L67 mild mods
Results 1 to 20 of 142
  1. #1 Re: L67 mild mods
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    You can run a 3.4 with a downpipe only. But IMO safely to do it I would at least get a zzp 1.0 pcm and a 180 degree thermostat. With the zzp 1.0 pcm they send you a pcm and you just plug it in, nothing else is needed.I would never run a 160 because the car will never get warm enough to go into closed loop mode plus it can throw a CEL. Its not needed. Also you do not need a 3" exhuast. The headers will bolt to your stock catback. I would not waste the time on running true duals. All youre doing is adding weight with no gains. The stock cat back flows good enought up to 400 whp. You will be nowhere near that with the mods youre doing.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  2. #2 Re: L67 mild mods
    Quote Originally Posted by t24moore View Post
    Not really, this is where the discrepancies lie.
    Can you run a 3.4" with plugs/t-stat/canned PCM/downpipe? Sure.
    Can ALL cars? Not in any reality.
    Most of these cars are getting older...and can't handle what they could off the showroom floor 10+ years ago.
    Infact, many people here still get knock with headers and a 3.4"...and a CUSTOM wideband tune...
    Which is why I say...valvetrain mods are key...and a tune > pulley envy; I'd run a stock pulley with headers and a leaner AFR + higher timing and running a piggy AFR and stock timing or less with a 3.4".
    That's the main reason behind my Safely Modding thread. It points people in the SAFE direction, not like all the vendors that just say (Let's take ZZP for example)..."BUY OUR STAGE 1 OR 2 OR 3 PACKAGES AND GO SUPER FAST WITHOUT SCANNING THE CAR".
    First things first should be maintenence.
    Second, a way to scan the car...ALA tuner...or aeroforce.
    Third, address the exhaust issues...you want to get rid of: AT THE LEAST the crappy front manifold, downpipe, and the u-bend...which can be easily done with a cheap set of headers...which are about, if not less than the price of a downpipe now days.
    Fourth, then think about a pulley system...like an MPS...try a 3.6", then a 3.4"...then if that works for you...then re-tune for it...buy a wideband...make it spot on...
    Tossing crap on a car and hoping for the best isn't the best route to go about it.
  3. #3 Re: L67 mild mods
    Feb 2008
    Houston
    I forget that a lot of people have motors that have upwards of 160+ miles nowadays. I swapped my motor for a newer L32 with 50k. Thats a sound order you listed there.
  4. #4 Re: L67 mild mods
    I don't remember typing this.
    Maybe you should skim it again.
  1. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  2. A few new mods...take a look!
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 04-05-2010, 12:39 AM
  3. l36 mods want to get into the 14s
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-17-2010, 12:38 AM
  4. ZZP PCM and other mods
    By Talsition in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 03:39 PM
