Throwing copper = spinning the bearings.
I'm not totally convinced that the rings are the cause of popping the pistons.....the rings aren't in the same spot on every piston, in fact they rotate around the piston as the engine is running. It's more of the design of the heads and combustion chamber IMO....because the pistons break in the exact same place....every single time.
