Thread: 01 gtp pulley question
Results 1 to 16 of 16
  1. #1 01 gtp pulley question
    Feb 2015
    I bought a 01 gtp about a year ago and the owner had said it had a smaller pulley on the supercharger. I asked what size and he wasn't sure so I didn't think much of it at the time. Fast forward to now I checked the pulley and it looks like it's stamped with a gm part number, the number is 86016. I searched the web and didn't come up with much. Is this the factory 3.8" pulley? It has a 180 t Stat but as far as mods go that's it.
    Sent from my SAMSUNG-SM-N910A using Tapatalk
  2. #2 Re: 01 gtp pulley question
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    3.8"is stock pulley size not sure if you can just measure it or not
    Sent from my SAMSUNG-SM-G870A using Tapatalk
  3. #3 Re: 01 gtp pulley question
    Feb 2015
    I took a tape measure to it but with the bolt sticking out of the center of the pulley it's tough to get and accurate read on it
  4. #4 Re: 01 gtp pulley question
    Get one of these.
  5. #5 Re: 01 gtp pulley question
    Feb 2015
    I can't justify buying a set of calipers to measure one pulley one time
  6. #6 Re: 01 gtp pulley question
    you got a harbor freight near by? they got one for 5 bucks. works fine. i used it to measure the hub on my winter wheels so i could get spacer rings for em.
  7. #7 Re: 01 gtp pulley question
    Mar 2014
    Tucson
    It's a stock pulley. I'm going to bet there's an "R" 180° from that part number also...
  8. #8 Re: 01 gtp pulley question
    Feb 2015
    I'll have to check harbor freight out. I'm about 45 minutes from the closest one. And yeah there is an R stamped on it too.
  9. #9 Re: 01 gtp pulley question
    It's stock..
    The size is 3.8"
  10. #10 Re: 01 gtp pulley question
    St. Louis
    And put the stock 195* stat back in. If the car isn't tuned for the lower temp thermostat it's not doing you any good since the fans are still set to come on around 212*. You may actually be loosing fuel mileage since the car isn't getting up to temp. These motors were designed to run hot.
  11. #11 Re: 01 gtp pulley question
    Feb 2015
    I was actually just thinking about that. In the year I've owned it the fans have only kicked on twice. He also said he was running colder plugs in it. If that's the case should I throw some 605 coppers in it? Or just use what is called for stock?
  12. #12 Re: 01 gtp pulley question
    Quote Originally Posted by FordMan77 View Post
    Not really.
    But okay.
    Heat is what breaks everything down in these cars, and the rated temp that the t-stat is at is a solid 10-20* less than what the actual temp is...example: my 160* constantly ran north of 175*.
    The tune will help but tossing the 180* in there now isn't going to harm anything. And if you think you're really losing that much fuel mileage, then I don't know what to tell you. I didn't even notice a difference with my 160*, except for letting it run for a minute or two longer on cold mornings.
  13. #13 Re: 01 gtp pulley question
    Feb 2015
    I drive mostly highway which keeps it pretty cool but this past winter my car never warmed up above 170ish
  14. #14 Re: 01 gtp pulley question
    St. Louis
    Quote Originally Posted by blueguy View Post
    Not really.
    But okay.
    Good to know. Never tried it but since everyone here suggested to leave it alone if not tuned for it that's what I always went with.
  15. #15 Re: 01 gtp pulley question
    Everyone should own a digital caliper..worth every penny there's somethings where a measuring tape won't cut it.
    04 Comp G.
  16. #16 Re: 01 gtp pulley question
    Mar 2014
    Tucson
    Digital is for slackers. Battery never dies on my dial calipers!
  1. Pulley question??
    By Pontiacpride in forum General W body
    Last Post: 04-17-2015, 07:23 PM
  2. 3.4 Pulley Question
    By psi in forum Introductions/Noob Questions
    Last Post: 07-30-2014, 05:54 AM
  3. S/C Pulley question
    By PMave in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-01-2009, 12:22 PM
  4. To Pulley or not to Pulley is not the question.... SIZE IS
    By massivesystem in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2009, 10:43 AM
  5. pulley question
    By novmadman in forum General Tech Discussion
    Last Post: 02-08-2009, 07:05 PM
