Thread: bad snout seal i thought! but maybe not;)
Results 1 to 6 of 6
  1. #1 bad snout seal i thought! but maybe not;)
    Apr 2012
    Cape Breton,Nova Scotia
    So! my l67 has the stone breather on the end of pulley nut. I noticed the pulley "weeping" around the nut. Its def supercharger oil but, if it was the snout seal wouldn't it leak out from behind the pulley? on the face of the snout? I have a slight drip that runs down every few hours from around the nut. Now thinking it could be the breather plug but man oh man I have no idea... the pulley was never removed before and the nut was never cracked... any ideas?
  2. #2 Re: bad snout seal i thought! but maybe not;)
    Donating Users crock's Avatar
    Traverse City, Michigan
    Mine is leaking also.... I just replaced LIM, and water pump and up. And I noticed that it was leaking.
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  3. #3 Re: bad snout seal i thought! but maybe not;)
    Mar 2012
    lakewood
    Just monitor your sc oil. It is just a breather/vent.I would not be to concerned
  4. #4 Re: bad snout seal i thought! but maybe not;)
    Have you drained and filled the SC lately? Ever? Likely it's just full enough that it's able to push a little oil with the pressure out the breather. I almost always smell oil when working near the pulley end of a charger.
  5. #5 Re: bad snout seal i thought! but maybe not;)
    Apr 2012
    yup i did do an oil swap a few months ago and havent ran the supercharger since, this is a motor swap and im going to be running it soon
  6. #6 Re: bad snout seal i thought! but maybe not;)
    Call it normal enough. And if you had the SC sitting in a position where the snout was aiming down at all.. it'll run right out that breather. I recently tested this theory.
  1. Snout seal replacement.
    By Deno in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2020, 09:00 AM
  2. "New Style" M90 snout seal installment made easy!
    By GR8racingfool in forum How To Write-Ups/Tech Tips
    Last Post: 06-26-2013, 12:47 AM
  3. Leaking oil - is it the pan or seal?
    By SJAndrew in forum General Tech Discussion
    Last Post: 12-10-2010, 03:07 PM
  4. front oil seal
    By sloppyjoe616 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2009, 05:15 PM
