Thread: Oil leak and coolant smell
Results 1 to 11 of 11
  1. #1 Oil leak and coolant smell
    SE Level Member littlerobinson75's Avatar
    wrentham, MA
    Hey all, I just got home from my last year in college to find out my 98 GTP is leaking oil from the back of my engine and it seems to be coming from below my throttle body. There's no oil coming from the rear valve cover, the gasket got replaced in march. I'm not 100% sure where it is coming from but the back of my engine is coated with oil and it was just sprayed with cleaner and washed about 2 weeks ago. I was told that it could be coming from my LIM. I also noticed some oil that smelled like coolant under my supercharger on the intake manifold. I was told that if I need to replace the LIM to use a metal and rubber gasket. I was wondering if any one had been down this road and had any ideas. Thanks
  2. #2 Re: Oil leak and coolant smell
    St. Louis
    Yes, this is VERY common on these motors. We have all done it, lol.. Do a quick search for LIM gasket replacement and I'm sure there is a how-to in there. Yes, get the aluminum framed gaskets from a GM dealer. You will also need fuel injector o-rings, RTV, coolant (either refill w/ Dexcool, or flush the entire system clean and go with the green stuff), thread sealer for the LIM bolts, coolant elbows (can get them in the "HELP" section at most parts stores), 1 quart of oil to wash out the lifter valley, then enough oil and filters to do 2 changes. One after 10 min. of running, then again for the final change.
  3. #3 Re: Oil leak and coolant smell
    Tampa
    I might have a LIM leak as well but I think I fixed a bigger one by replacing the heater hose connectors (elbows). Apparently its a common problem at least for higher mileage GP's (which most probably are anyway). I'd say it cost less than $10 for parts and RTV plus a standard socket set and any coolant draining items.
  4. #4 Re: Oil leak and coolant smell
    Just so you believe him... Fordman nailed it. Extremely common. and..we've all done the gaskets. Hop to it.
  5. #5 Re: Oil leak and coolant smell
    wrentham, MA
    I talked to my friends dad who's a retired GM mechanic, he said he saw these repairs on a weekly basis. I appreciate the heads up on the injector O-rings, I didn't know about those it's probably a take it a part and realize it after things. Thanks for the help, I appreciate it!
    GT Level Member Erics00LS's Avatar
    Lindenhurst, IL
    Get a felpro set and it comes with everything for about a hundred and I do mean everythingon the top half. Might as well
    Sent from my SPH-D700 using Tapatalk 2
    '03 Buick Park Avenue Ultra - a few bolt ons
    http://www.facebook.com/groups/greatlakesareacarenthusiasts
  7. #7 Re: Oil leak and coolant smell
    wrentham, MA
    Yea I had seen those sets I was a little concerned about the GM and other sets that didnt have all of those parts with them. I might as well just get one before I get in there and realize I need them.
  8. #8 Re: Oil leak and coolant smell
    St. Louis
    As long as the Fel-Pro kit has the aluminum LIM gaskets then yes, I'd go with that.
    Lindenhurst, IL
    They're plastic.
    Lindenhurst, IL
    Don't use dexcool and there won't be any issues honestly. That and plug your intake manifold.
  11. #11 Re: Oil leak and coolant smell
    Quote Originally Posted by Erics00LS View Post
    Dex has nothing to do with the issue Eric. I have personally tested this and the issue wasn't the coolant, it was the gasket and heat. I had a set of plastic gaskets going bad in under 20K w/o any dex in the car. Series I cars never had Dex and their gaskets looked identical when removed.
  1. faint coolant smell..
    By danielle15 in forum General Tech Discussion
    Last Post: 04-04-2011, 08:33 PM
  2. Coolant Smell-Grand Prix GT 2007
    By Allison in forum Introductions/Noob Questions
    Last Post: 10-29-2010, 07:23 AM
  3. I smell coolant but can't find a leak 01 GP GTP
    By smooth01gtp in forum Introductions/Noob Questions
    Last Post: 02-16-2010, 07:06 AM
  4. Coolant smell in car
    By thewaitinggame in forum General Tech Discussion
    Last Post: 12-13-2009, 04:21 PM
  5. coolant smell
    By Charged97 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2009, 12:46 PM
