Thread: boost issues
Results 1 to 3 of 3
  1. #1 boost issues
    Destroys cars izup69's Avatar
    Iowa
    Ok to start out with im only seeing 3.5psi of boost. When the car is cold say 120-160* I get plenty of boost (yes I know its very bad for the car).
    I have checked all the usual suspects bbv vac leaks ect. I have codes for the maf and the tps. I have replaced both of them twice. If I clear the codes the car runs like **** like the tps took a dump. No throttle response. The problem only started when it started to get warm out. No fluctuation in the rpms.
    Here is a link to a log zipExport-2012-06-02_01-28-652.zip download - 2shared
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  2. #2 Re: boost issues
    Omaha, NE
    Have you cleaned the maf?
  3. #3 Re: boost issues
    Iowa
    more then once still no change
  1. 02 GTP boost issues
    By 02GTPanniversary in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2011, 04:49 PM
  2. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  3. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
  4. Boost Issues
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-01-2010, 11:29 AM
