Thread: Engine code deciphering
Results 1 to 20 of 24
  1. #1 Engine code deciphering
    SE Level Member chuckbattams's Avatar
    BRANTFORD, ONTARIO
    right now my engine is not working, and I have not been able to fix it. So I've been searching for a replacement, I think I've found one with low milage on it, just that when the owner sent me the engine numbers, well, I have not been able to find out any info on the net about the year of the engine. He told me it was either a 1996, or 97 or 98 ... my car is a 98 gtp and this motor is definately an gtp, cause it has the S/C on it.
    The info he sent me is ... 60er bkz-aa 10bkz and b0216715
    Any help would be appreciated.
    Thanks
    Chuck
  2. #2 Re: Engine code deciphering
    right beside the part number it'll say "SERIES II" if its a series II or III.
    Unfortunately every series II and up uses the same block.
  3. #3 Re: Engine code deciphering
    BRANTFORD, ONTARIO
    My research says that GM went to series II in 1997 and series III in 04 ... so my fingers are crossed that it is a series II, being he did not really know the year.
  4. #4 Re: Engine code deciphering
    BRANTFORD, ONTARIO
    Oh, well is that not sweet of GM ... was hoping there would be some info for a date on them numbers. '0'
    Thanks for the reply Matt.
  5. #5 Re: Engine code deciphering
    Well to be frank: the only thing that won't work is a series I.
  6. #6 Re: Engine code deciphering
    Rebuilding the 3.8L Buick Engine: Engine Builder
    Series II came out in 95 actually.
    Heres the block part numbers:
    Series I s/c: 24502134 or a 24502441
    Series II early (95/96) (no pins for LIM end pieces): 24502287
    Series II Late (97+) (pins for LIM end pieces): 24506029
  7. #7 Re: Engine code deciphering
    NA series II arrived in 95
    SC series II arrived in 96
    In 98 pins arrrived for the LIM end seals.
    Chuck, a picture of the SC would give us more info.
  8. #8 Re: Engine code deciphering
    BRANTFORD, ONTARIO
    I would post BillBoost, but everytime I try to upload, it looks for an url...
    Just found out, it is a series II and it has, I mean .. only has 39,843 kms on it That's sweet.
    Thanks for Your help Matt.
  9. #9 Re: Engine code deciphering
    Goodluck with the swap!
  10. #10 Re: Engine code deciphering
    Here's a 96/97 motor. The way to tell is there is a black vacuum tree on the sc by the TB on the front. The 98+ does not have that.
  11. #11 Re: Engine code deciphering
    BRANTFORD, ONTARIO
    I'm confused,, ... I just got the code off the block ... it is 24506029 ... also says 3800 II series
    But ...
    I took my S/C off my 98 gtp and it does not fit, :*(
    Is there different types of S/C's out there?
  12. #12 Re: Engine code deciphering
    BRANTFORD, ONTARIO
    BillBoost, unfortunately for me, this motor I bought did not come with a S/C on it. That plus a few other facts, for example, no exaust manifolds, is how I managed to talk him down in price
    Matt included some block numbers, so I'll compare them, hoping it is a 98 or newer, will the 96 work? If for some mis-fortune that is what I have?
    96 sc block is the same minus lack of lim gasket end piece locating pins.
  14. #14 Re: Engine code deciphering
    BRANTFORD, ONTARIO
    Alrite, took fuel rail off to try, and it does not fit, so it is obvious an S/C motor... am I able to take the S/C and head off my blown motor and add it on this one?
  15. #15 Re: Engine code deciphering
    Mar 2012
    NC
    Are you sure it's a supercharged engine? The way to tell is there injector holes in the lower intake manifold or in the cylinder heads.
  16. #16 Re: Engine code deciphering
    Mar 2012
    NC
    Yes you are. If you do this, make sure you send your heads out to be inspected and freshened up to avoid further issues down the road.
    High comp pistons. Youll need headers
  18. #18 Re: Engine code deciphering
    BRANTFORD, ONTARIO
    What would headers accomplish?
    More air flow...
    So, guess I need head gasket, and as hitman says, get head re-grinded from my car before installing onto the new motor.
    Is it worth the effort?
    Or should I now sell this motor which I now know is a non-S/C 3800 and look for another 3800 which is an S/C 3800?
    Learning experience ... that is for sure!
  19. #19 Re: Engine code deciphering
    if the engine is a non s/c, the pistons will be setup for 9.4 static compression ratio (versus 8.5 of the s/c engine) which requires either a permanently open bypass valve (Not the best of ideas, but it can work) or some sort of exhaust flow mod to run with the supercharger with a stock pulley.
    You could also install a 4.0-4.2 " pulley on the blower.
    It can add up real quick but supercharged engines are pricey in Ontario.
  20. #20 Re: Engine code deciphering
    BRANTFORD, ONTARIO
    Hey Matt, any suggestions of where to get the proper headers? Anything else needed to purchase?
  1. Help Deciphering a scan
    By xxmattfxx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 09:30 PM
  2. Engine Code
    By the955iman in forum General Tech Discussion
    Last Post: 04-17-2009, 04:40 PM
  3. 4T60-E (and HD) ID TAG deciphering info
    By Sinister Performance in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-31-2009, 08:42 PM
  4. engine code
    By whitegtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-15-2009, 04:42 PM
  5. 4T65-E (and HD) ID TAG deciphering info
    By Sinister Performance in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-27-2008, 01:37 PM
