Thread: Installed Overkill PCM
Results 1 to 20 of 71
  1. #1 Re: Installed Overkill PCM
    Barksdale AFB, LA
    CASE learn can also be accomplished by a tuner or the latest version of Aeroforce gauges.
    2009 Subaru Impreza WRX STI
  2. #2 Re: Installed Overkill PCM
    GT Level Member massivesystem's Avatar
    Apr 2008
    Quote Originally Posted by Sabrewings View Post
    So I cant just drop in a PCM? I need to perform other steps in order for everything in my car to work correctly?
  3. #3 Re: Installed Overkill PCM
    Banned
    Wichita Falls, Texas
    Quote Originally Posted by massivesystem View Post
    Normally yes, you can just drop it in.
    But seeing as your having problems it would be best to do a CASE learn and see if the problem is resolved by it.
    However.... I don't see how it would effect your gas gauge not working correctly.
  4. #4 Re: Installed Overkill PCM
    Apr 2008
    So I pulled the Overkill PCM and reinstalled my factory one ( I kept it). and my fuel gauge returns to normal
    Well I sent a email off to Will and will ave to see what he has to say I guess.
    I am lost
  5. #5 Re: Installed Overkill PCM
    Banned
    I am lost
    Honestly sounds like something was done incorrectly with the PCM then.
  6. #6 Re: Installed Overkill PCM
    Barksdale AFB, LA
    Or the PCM is faulty.
  7. #7 Re: Installed Overkill PCM
    Jersey
    When i installed mine i had no problems. I did read somewhere that there is more problems with the newer model GP's and overkill pcm's. When i got my pcm i emailed Will and asked if i needed a "case learn" he said only if you get a check engine light, and i didnt. So i guess im in the clear?
    16' wrx sti- stock
  8. #8 Re: Installed Overkill PCM
    Barksdale AFB, LA
  9. #9 Re: Installed Overkill PCM
    Aug 2008
    SOUTH TEXAS
    Never heard of that happening with a pcm.
    Let us know the outcome!
    TOGs//Stge III ZZP Blower//LS1 tb// 85 maf//XP cam //105lb spings//3" Dp& high flowcat//3.2",3.0"
    Ud plly//Msd wires//Aut 103's//CAI//ZZ PCM//ZZ P shift kit//42.5lb. 13.3@104MPH DEC 08
  10. #10 Re: Installed Overkill PCM
    Apr 2008
    Quote Originally Posted by GTP4 View Post
    Like I stated above Will at Overkill thought-
    It seems as though this is an issue with 07s using the older PCM box and isn't a faulty PCM. GM has likely changed how the fuel gauge is calibrated for the 07 model year.
    I would think that fuel calibration would be the same for 05,06,07???
    thoughts
    2007 Pontiac Grand Prix GT Series III 3.8 Super Charged
    AL 104's Plugs, 180* T-Stat, Tuned PCM , Custom CAI is complete and installed, AeroForce Interceptor gauge, Smoothflow 3.5 pulley with 0* KR, SSAC SS Headers. 6000K HID
  1. Overkill PCM's
    By spidamanSS in forum PCM Tuning
    Last Post: 10-16-2008, 08:13 PM
  2. overkill springs...
    By YoungGTP in forum Brakes/Suspension/Chassis
    Last Post: 09-04-2008, 07:46 PM
