Thread: 1.9 Terra Roller Rockers and Pushrod angle...
Results 1 to 4 of 4
  1. #1 1.9 Terra Roller Rockers and Pushrod angle...
    May 2012
    Fargo, North Dakota
    ...will I have an issue with this? And if so, is there a fix?
    Thanks for reading...
  2. #2 Re: 1.9 Terra Roller Rockers and Pushrod angle...
    Not sure what the issue is. Didn't yella's come with pushrods that were the correct length?
  3. #3 Re: 1.9 Terra Roller Rockers and Pushrod angle...
    Feb 2009
    flintnasty MI
    angle as in they are really close to the heads...
    The YT rockers are probably going to be a bit better than modded stock... but I would check them on a L32 motor.
  4. #4 Re: 1.9 Terra Roller Rockers and Pushrod angle...
    Melbourne
    Hi Guys,
    The pushrod is quite close, obviuosly due to the higher ratio. Make sure you check clearance especially with the GM castings. Weve seen many castings have cast flashing that needs to be filed back in some cases. Also Im assuming they are unmodified factory heads. Just check if they have been milled or not also /.
  1. 1.9 terra yella roller rockers
    By nascartech in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2010, 11:17 AM
  2. Pushrod length with ProMagnum rockers?
    By Infinity9999 in forum General Tech Discussion
    Last Post: 09-08-2009, 05:13 PM
