Thread: how do i remove the supercharger pulley? and vice versa
Results 1 to 20 of 28
  1. #1 how do i remove the supercharger pulley? and vice versa
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i have a 99 gtp i wanna swap to a 3.6'' pulley (with supporting mods) how do i remove the stock pulley preferably on the car? and then how do i put the new pulley on? id like to avoid buying the expensive zzp pulley puller because im only gonna do this once
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: how do i remove the supercharger pulley? and vice versa
    you need the puller, period. theres a guy who makes them and selling a few still. link......http://www.grandprixforums.net/pheno...ler-42711.html
  3. #3 Re: how do i remove the supercharger pulley? and vice versa
    GT Level Member afallucco's Avatar
    Ohio
    Here are the instructions on how to use the puller, http://www.zzperformance.com/blog/wp...uller-Gen2.pdf
    Also just choose rental and rent it and send it back right away.
    2004 Grand Prix GTP
    |FWI | HP Tuner | 1.9 Rockers | SD Headers | 3.5MPS | 97-03 control arms w/GMPP sway bar|
    Planned soon: s3x, custom ported heads, IC
    Thug life, that's how we live.
    Quincy, Mass
    You could post in the wanted section, there's tons of people in Michigan and I'm sure one of them has a puller and is willing to help you out.
    No more GP 04 Impala SS Indy:
  5. #5 Re: how do i remove the supercharger pulley? and vice versa
    Florida
    or post and find someone local who has one and will come and help you.
  6. #6 Re: how do i remove the supercharger pulley? and vice versa
    GTP Level Member buickman104's Avatar
    NYC
    Yup, a forum member from New Jersey helped me out.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  7. #7 Re: how do i remove the supercharger pulley? and vice versa
    Mar 2012
    lakewood
    I pulled mine of with the large auto zone puller. Keep in mind, you can not turn back.I destroyed my oem pulley, then used all thread and a nut to install the new one.cost me 5$
  8. #8 Re: how do i remove the supercharger pulley? and vice versa
    good way to destroy the snout^^^
  9. #9 Re: how do i remove the supercharger pulley? and vice versa
    Mar 2012
    lakewood
    If not careful,I agree
  10. #10 Re: how do i remove the supercharger pulley? and vice versa
    Oct 2011
    Michigan
    ill have someone do it this is one of those specialty jobs i might just get an MPS but idk if its worth the money
  11. #11 Re: how do i remove the supercharger pulley? and vice versa
    a mps is well worth the money if you are going to be modding at all and plan on dropping pulley sizes.
  12. #12 Re: how do i remove the supercharger pulley? and vice versa
    Oct 2011
    Michigan
    idk if im gonna drop it again but its only a little more for one so i might as well
  13. #13 Re: how do i remove the supercharger pulley? and vice versa
    SE Level Member Mike Kopstain's Avatar
    Chicago, IL
    You're going to put the pulley on there, feel the difference in power and then immediately want to mod it more and drop the pulley again. Once you get to that point you'll be kicking yourself if you have to press another pulley off and back on. MPS all the way.
    [cheap plug] We have MPS' and pullers in stock with free shipping[/free plug]
    Thinking about shopping with ZZP or the other guys? - Order with us instead and we'll give you a 5% off coupon code for your next order! Click here to learn how!
    Like us on Facebook!
  14. #14 Re: how do i remove the supercharger pulley? and vice versa
    Oct 2011
    Michigan
    whos we? W Body Store?
  15. #15 Re: how do i remove the supercharger pulley? and vice versa
    Chicago, IL
    Oh yeah... :-)
  16. #16 Re: how do i remove the supercharger pulley? and vice versa
    Oct 2011
    Michigan
    well your MPS cost the same as ZZP but i found your 12'' dual piston front brake upgrade kit and thats a really good price
  17. #17 Re: how do i remove the supercharger pulley? and vice versa
    Stopping > Going Faster...if you can't do the first part...
    12" upgrade, especially the FBody brakes work great.
    Also, do NOT use a regular 3 jaw puller...not only can it damage the snout physically, it can also bend the snout shaft internally...
    Rent one from Mike, or get one from a local.
    It's worth it.
    Do it right the first time and get an MPS all the way.
  18. #18 Re: how do i remove the supercharger pulley? and vice versa
    Chicago, IL
    If you're in a large area find your local club. Chances are someone has a puller. Otherwise we rent them.
  19. #19 Re: how do i remove the supercharger pulley? and vice versa
    Oct 2011
    Michigan
    how much do you charge to rent them? and can this be done on the car or does the blower need to come off?
  20. #20 Re: how do i remove the supercharger pulley? and vice versa
    Jan 2012
    Philadelphia
    what supporting mods do you have?
  1. Impala exhaust on GP and vice versa
    By scottb1982 in forum General Tech Discussion
    Last Post: 02-13-2011, 10:36 PM
  2. How to remove Supercharger Belt?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2010, 03:51 PM
  3. How to remove the supercharger ?
    By ryangtp89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2009, 04:20 PM
  4. Turbo vice supercharger
    By John_Shughart in forum Turbo
    Last Post: 06-06-2008, 05:18 PM
