Thread: seafoam
Results 1 to 20 of 40
  1. #1 seafoam
    SE Level Member samuelcb409's Avatar
    Galveston, Texas
    my girl has 03 gtp and was told to run seafoam, to clean injectors, better mpg etc... wanted to see any specific way to do this and if it will cause any damage to the car
    MODS: 3.0 MPS, CAI, SD Headers w/Custom 3"DP, 160* T-Stat, NGK TR6, Full Size intercooler, #42.5s, Ported LIM & Gen III, LS1 TB w/85mm MAF , s1x Cam, #90 Springs, Intense Pushrods, EGR Delete, Cat and U Bend Delete, Magnaflow Resonator & Mufflers, Fully Built ZZP Trans, 2800 stall Tuned by KHP Peformance
  2. #2 Re: seafoam
    Omaha, NE
    Add some to the gas, run some through the brake booster, and some people add some to the crank case.
    Run it all through, then replace your spark plugs and oil and you'll be done.
  3. #3 Re: seafoam
    Galveston, Texas
    Ok just wanted to make sure it wouldnt damage the sc or anything
  4. #4 Re: seafoam
    Omaha, NE
    Nope, the supercharger will be fine, just don't put any seafoam in the supercharger oil.
  5. #5 Re: seafoam
    Put 2/3 of it in gas tank then start car pull brake booster and slowly add seafoam into brake booster until car dies, wait 10-15 min then start car and let run till it stops smoking.
  6. #6 Re: seafoam
    Galveston, Texas
    Ok thanks
  7. #7 Re: seafoam
    GTX Level Member GOTIT4CHEAP16's Avatar
    Bowie, MD
    Run it through the vacuum port going to the lim under your supercharger snout. Dont use the brake booster because it will eat your the coating on your supercharger coating.
    Gen V, 3.0, Stage 2 heads, XP Cam, SD Headers, N*, LQ4, ZZP Stage 2 Gen 3 Intercooler, CAI, AL 104's Gapped to .055, #130 Springs, 42.5lb Injectors, ZZP Tune.
  8. #8 Re: seafoam
    Quote Originally Posted by GOTIT4CHEAP16 View Post
    This is false.
    If that was the case I'd never have blower rotor coating.
    The GenIII coating fails miserably over time regardless of methanol injection, seafoam, etc. GM coated it improperly.
  9. #9 Re: seafoam
    You mean Eaton?
  10. #10 Re: seafoam
    GM doesn't order specs for their stuff and Eaton builds it per their request?
    Therefore...GM had crappy ideas?
  11. #11 Re: seafoam
    Since when?
  12. #12 Re: seafoam
    Since when?
    Oh funny guy.
    You are one.
  13. #13 Re: seafoam
    I wouldn't put anything but air through the rotors personally. I singlehandely stripped coating off a set of rotors with TB cleaner while I had the blower off. Yeah..early on I learned the hard way.
  14. #14 Re: seafoam
    ok time for a noob question...bear with me on this one
    what is the coating for?
    SMGPFC Member #10
  15. #15 Re: seafoam
    It seals the rotors to the case better than machining alone.
  16. #16 Re: seafoam
    for like a air tight seal type thing
    SMGPFC Member #10
  17. #17 Re: seafoam
    Yes. Better boost charge w/o all the heat of the previous M62's. Because you do know that 3800's came with M62's in the early to mid 90's right?
  18. #18 Re: seafoam
    i do now ..lol
    is there not a way to put a coating back on it after it gets taken off?...seems like a it would be a wear item for maintenance
    SMGPFC Member #10
  19. #19 Re: seafoam
    It's a million dollars and we are all cheap
  20. #20 Re: seafoam
    ohok i gotcha..thanks bill
    SMGPFC Member #10
  1. Seafoam???
    By Iceman6669 in forum General Tech Discussion
    Last Post: 07-17-2011, 11:44 AM
  2. Proper way to seafoam 04+ S/C?
    By dirtmaster88 in forum 04+ Specifics
    Last Post: 01-11-2010, 04:32 PM
  3. Seafoam
    By BwolfGT in forum Off Topic Discussion
    Last Post: 09-20-2009, 03:54 AM
  4. Seafoam
    By my engine is upside down in forum General Tech Discussion
    Last Post: 06-03-2009, 06:19 AM
  5. Seafoam
    By J_Man55 in forum General Tech Discussion
    Last Post: 08-08-2008, 08:23 PM
