Since you replaced the sender, you may have caused a leak on the tube that goes into the top of the pump. Remove the tube and check the o-ring inside of the connector. If the o-ring looks good you could put a little silicone lube on the tube before reconnecting. This will help it seal. Make sure to either clear the codes with a scanner or disconnect the battery for 15 minutes. Drive for 100 miles or so and see if DTC reappears.
P0440
Reference: OBD-II Trouble Code: P0440 Evaporative Emission Control System Malfunction
This indicates that a part of the EVAP control system is no longer fuctioning correctly. The EVAP system consists of many parts, including (but not limited to) the gas cap, carbon canister, fuel lines, purge valve, and other hoses. The (EVAP) emission control system prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
Symptoms
You likely won't notice any drivability problems.
Causes
A code P0440 could mean one or more of the following has happened:
  • The gas cap is not installed or working properly
  • The purge solenoid has failed
  • The canister is plugged and not working properly
Possible Solutions
With a P0440 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
  • Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
  • Inspect the EVAP system for cuts/holes in tubes/hoses
  • Inspect for damaged or disconnected hoses around the Evap purge solenoid
  • Check and/or replace the sensor
  • Check and/or replace the purge valve
  • Have a professional use a smoke machine to detect leaks
