My 1997 gtp with 156k miles has started to "jump" under acceleration sometimes.
Started yesterday when I was going up a long hill, I was crusing at about 1600rpm or so and I gave it a little gas to maintain the same speed, then it started "jumping". So I gave it more gas and it down shifted and no more problem.
Now today I took it out and it did it a little bit under normal acceleration in first gear, then 15 mins later in 3rd or 4th gear.
It dosent do it all the time, its actually kinda hard for me to get it to happen.
But it seems to do it at lower rpms.
When it did happen I didnt see the tach move at all. No rpm drop.
Idle is fine, except when I start it after Ive been driveing it for a while, It will idle low (600 rpm) and I give it a little gas and no issue.
I can also hear a "poping" in my exhaust crusing at 55mph. Sounds like a slight backfire or somthing?
SES light has been on for a month or 2, I ran the codes back then and it said O2 senors were bad. (never fixed it tho)
Havent ran the codes recently.
Tried looking up this problem and these are thing I think I should check:
Fuel filter
maf
iac
knock sensor
o2 sensors
Any help would be much appreciated.
Thanks,
Eric
