Thread: Top Swap Shopping List and a question
Results 1 to 20 of 26
  1. #1 Top Swap Shopping List and a question
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    Below is my parts list for my S3 top swap. I got a good deal on the Gen5 and L67 heads with #105's already in them from 1bad3800
    The one question I have is about installing the new pulleys, am I reusing the existing bolts from the NA setup or do I need to bolts?
    PARTS LIST
    Head Bolts,
    Head Gaskets
    Rocker bolts
    Valve Cover Gaskets
    Valve Cover
    Harmonic Balancer From the SC motor
    Tensioner for SC belt
    Idlers for Sc belt
    Coil Pack Bracket
    Lower Intake Manifold from the SC motor
    Lower intake Manifold Gaskets
    Fuel Rail
    Fuel Injectors and zzp wires
    1 Step Cooler Spark Plugs
    Heads from SC motor
    Supercharger
    Supercharger Gasket
    Supercharger Belt
    Throttle Body from SC motor
    Throttle Body Gasket
    Colder Thermostat Tunned PCM
    Vacuum hoses
  2. #2 Re: Top Swap Shopping List and a question
    Florida
    fuel lines will need to change.
    also if your using a SC pcm then you will need the wire kit to swap to the diff MAP sensor and add the BBV solenoid
  3. #3 Re: Top Swap Shopping List and a question
    Apr 2012
    Middletown DE
  4. #4 Re: Top Swap Shopping List and a question
    Apr 2012
    Middletown DE
    Quote Originally Posted by Z34Phoenix View Post
    ZZP top swap PCM Where can I get this wiring kit? I looked around ZZP didnt find it. and (BBV) = blow back valve?
  5. #5 Re: Top Swap Shopping List and a question
    I didn't change my fuel lines.
    No ZZP injectors.
    Do not bother with L67 injectors unless you plan on sticking with the 3.8 pulley.
    If you want to venture into lucas 42.5's, know there is no solid injector data on them.
    Only guesses.
    Lower stand off bracket requires the bolts from the s/c engine.
    Upper coil pack bracket requires the nuts from the s/c engine. Namely for the tensioner.
  6. #6 Re: Top Swap Shopping List and a question
    same.
  7. #7 Re: Top Swap Shopping List and a question
    Banned
    Sioux Falls, SD
    Headers!!! and get ARP rocker bolts and head studs.
  8. #8 Re: Top Swap Shopping List and a question
  9. #9 Re: Top Swap Shopping List and a question
    Banned
    Sioux Falls, SD
    head STUDS.
    bolts are lame.
    Thats what i ment!
  10. #10 Re: Top Swap Shopping List and a question
    You'll want the bolts and nuts that came with the SC idler and SC tensioner, brackets etc. LIM bolts can be reused.
    Ensure you have a tube of RTV and a tube of pipe sealant (ptfe) on hand for the various bolts like LIM and SC idler.
  11. #11 Re: Top Swap Shopping List and a question
    Apr 2012
    Middletown DE
    The only thing that I am having trouble finding now is the "special" SC Tensioner bolt. I am being told its 13mm head with a 15mm stud.
  12. #12 Re: Top Swap Shopping List and a question
    It's a 13mm super small head on an M10 or M12 stud. Theres one on the motor. One
  13. #13 Re: Top Swap Shopping List and a question
    Texas
    Skip the ZZP wires.
    85 Corvette
    01 TA
    03 Z06
  14. #14 Re: Top Swap Shopping List and a question
    Apr 2012
    Middletown DE
    Quote Originally Posted by txslow6 View Post
    Skip the ZZP wires.
    Will i need to change the wire end at all? attached is a picture of the blower
  15. #15 Re: Top Swap Shopping List and a question
    Texas
    Wire end? I thought you meant spark plug wires. So which ZZP wires are you talking about?
    85 Corvette
    01 TA
    03 Z06
  16. #16 Re: Top Swap Shopping List and a question
    Apr 2012
    Middletown DE
    The wire in question is Caspers 109100 which i have bought through Jegs and will be buying the delco map sensor from napa
    I THINK.. I have everything now.
  17. #17 Re: Top Swap Shopping List and a question
    Apr 2012
    Middletown DE
    Could someone please tell me If I will be able to reuse the bolt from the NA Harmonic balancer for the SC Harmonic balancer
  18. #18 Re: Top Swap Shopping List and a question
    Yes
  19. #19 Re: Top Swap Shopping List and a question
    Apr 2012
    Middletown DE
    Yes
    Just called a local dealer and the part numbers are the same. Thanks again!
  20. #20 Re: Top Swap Shopping List and a question
    PS..that's off the top of my head. You might wanna check the part numbers say on Rockauto or something to be sure. Cause I won't be within screaming distance when you try it out.
  1. car shopping... :(
    By hondo in forum Off Topic Discussion
    Last Post: 05-18-2011, 02:13 PM
  2. LIM Shopping List
    By fri3dchick3n in forum General Tech Discussion
    Last Post: 04-18-2011, 12:10 PM
  3. Prioritizing Parts Shopping List
    By brandonl2000 in forum General Tech Discussion
    Last Post: 01-16-2011, 11:27 PM
  4. My Shopping List
    By ZR1Vette09 in forum General Tech Discussion
    Last Post: 03-17-2010, 11:04 PM
  5. Attempting '97 Dual Climate Control Swap- Building shopping list
    By JBONE in forum General Tech Discussion
    Last Post: 09-17-2009, 11:20 AM
