Thread: Misfiring on Cylinder 5
Results 1 to 4 of 4
  1. #1 Misfiring on Cylinder 5
    SE Level Member rell2005's Avatar
    Detroit / Grand Rapids
    After I replaced my Valve cover gaskets today, cylinder 5 began misfiring. There was not misfire last night as it drove fine. I checked and all the plugs and wires were fitted properly and the plug wasn't cracked. I put in new spark plug wires and replaced the plug only to see its still misfiring. My next guess is coil packs? ANY OTHERS IDEAS or SUGGESTIONS???
  2. #2 Re: Misfiring on Cylinder 5
    Apr 2009
    Fort Worth TX
    Make sure you didn't muck-up an injector wire. #5 is front farthest to the right.
    -----------------2 4 6
    FRONT motor
    passenger side
    -----------------1 3 5
    Front Bumper
  3. #3 Re: Misfiring on Cylinder 5
    check the plug wire for # 5, it may have been left on a manifold and got burnt up, you can switch coil packs around, and switch the wire, see it the mis follows.
  4. #4 Re: Misfiring on Cylinder 5
    I put new wires and a new plug in....and the wire for sure hasnt touched the headers...but im gonna switch the coilpacks tomorrow to see if it follows
  1. cylinder #3 misfiring
    By pontiacGTP1999 in forum Introductions/Noob Questions
    Last Post: 03-27-2011, 12:25 AM
  2. Misfiring HELP!!!!
    By Grandprix07gt in forum General Tech Discussion
    Last Post: 03-07-2011, 04:17 PM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
  5. Misfiring
    By Dropped GP GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2009, 07:15 PM
