X3. I was told the same thing, did it, and lost power. Don't do it. The only time it should be adjusted is if at WOT, all the bars aren't lite up on the boost indicator. Some times from the factory they don't come adjusted right. Not a common problem, but it does happen. If that's not the case, your fine where your at with it.
