Thread: No oil pressure
Results 1 to 5 of 5
  1. #1 No oil pressure
    Dec 2012
    Modesto ca
    I just got my motor all back to gether and i have no oil pressure. I checked everthing out and can not find the problem. i have the 3.8 gtp. I have full exhaust, k&n air filter, 3.6in pully,my pcm has been flashed, i have a 180 deg thermastat, shift kit, 2 stages colder plugs. I have just taken the motor all apart and put all new bolts, berrings, tephlon coated pistons, vs cam, ported new heads, and all the normal stuff you do in a rebuild. with the new the new oil pump i packed it full of vacoline and torqed it all down so im lost to why its not primming..... any ideas??????????
  2. #2 Re: No oil pressure
    Doesnt the oil filter neck have a spring in there or something? Or that might be on the pump.
  3. #3 Re: No oil pressure
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    did take the pump apart i though u had to prime the pump with oil or if you have it back togeather over fill it and see if it starts to get pressure dont start it just crank it over if you have a oil gauge see if u get pressure
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  4. #4 Re: No oil pressure
    Series II supposedly don't need to be packed. However, I know guys that have and had success. Before firing, I assume you disconnected the ICM and cranked for quite a while to get oil flowing via the pump?
    Ohio
    I'm going with the pressure spring is not even in there or seated wrong... But usually when seated wrong, you have a disgusting amount of pressure
  1. help installing oil pressure gauge and fuel pressure gauge
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-06-2012, 07:23 AM
  2. oil pressure
    By Stock4now in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-01-2011, 02:16 PM
  3. NO OIL PRESSURE HELP !!! plz help
    By shawn in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-25-2011, 07:26 PM
  4. vac pressure?
    By backinblackgtp in forum Audio, Security & Visual Electronics
    Last Post: 03-26-2010, 09:44 AM
  5. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
