Thread: Supercharger tensioner problem
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    I found the problem I think. The coil bracket isn't bolted flush.
    Lesson learned... Don't ever let your idiot friends work on your car.
  3. #23 Re: Supercharger tensioner problem
    hows everything running now, like are ya happy? (HOPE SO) i remember your last round with the ssm90 kit going bad.
    So happy!! I would never ever recommend the SS M90 kit over a top swap. The idle and cold starts are absolutely brutal with the ZZP kit, and tuning it was way harder. Plus 2 belts is awesome.
  5. #25 Re: Supercharger tensioner problem
    welcome to the club...finally!
  6. #26 Re: Supercharger tensioner problem
    GT Level Member 01GrandPrixTURBOGT's Avatar
    Dec 2011
    Decatur
    Sorry for reviving a old thread i just had a few questions. What size is the nut that tightens the tensioner to the coil bracket? I took the two studs out of my l36 heads for the bracket and put them in my l67 heads but i cant find a nut that will fit.
  7. #27 Re: Supercharger tensioner problem
    I know the nut size is a 13 mm. A 13 mm deep socket works nice. Not sure about the actual size of the stud it threads onto. Grab one from an auto wrecker. Takes 10 seconds. The other two nuts on the mounting studs are 15 mm.
  1. big problem with supercharger
    By bstuby in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-23-2010, 10:42 AM
  2. Supercharger coupling OR Supercharger belt tensioner?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 07-23-2010, 11:56 AM
  3. Supercharger leak and PSI problem
    By BullittGP1998 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 02:01 PM
