Thread: Injector duty cycle
Results 1 to 19 of 19
Impala ss sleeper Injector duty cycle 04-14-2012, 02:36 PM
dsmuts Re: Injector duty cycle 04-14-2012, 02:48 PM
afallucco As I said in the other thread... 04-14-2012, 02:49 PM
Impala ss sleeper Re: Injector duty cycle 04-14-2012, 02:50 PM
afallucco Have you done a wideband tune... 04-14-2012, 02:52 PM
Impala ss sleeper Re: Injector duty cycle 04-16-2012, 12:11 AM
rynoman03 Re: Injector duty cycle 04-16-2012, 12:12 AM
Impala ss sleeper Re: Injector duty cycle 04-16-2012, 12:19 AM
Impala ss sleeper Re: Injector duty cycle 04-16-2012, 12:22 AM
Tuner-Extraordinaire Re: Injector duty cycle 04-16-2012, 12:16 AM
Impala ss sleeper Re: Injector duty cycle 04-16-2012, 12:16 AM
rynoman03 Re: Injector duty cycle 04-16-2012, 12:17 AM
rynoman03 Re: Injector duty cycle 04-16-2012, 12:20 AM
Tuner-Extraordinaire Re: Injector duty cycle 04-16-2012, 12:24 AM
darkhorizon Re: Injector duty cycle 04-16-2012, 10:13 AM
rynoman03 Re: Injector duty cycle 04-16-2012, 12:24 AM
Impala ss sleeper Re: Injector duty cycle 04-22-2012, 08:46 PM
Tuner-Extraordinaire Re: Injector duty cycle 04-23-2012, 04:16 AM
afallucco You want around 11.5 afr for... 04-25-2012, 07:46 AM
  1. #1 Injector duty cycle
    Baytown,TX
    I have a 2005 impala l67,xp cam,gen v ,northstar tb,3.4 pulley,speed daddy headers,and my injector cycle was at 125 at wot and got 5*knock during high rmp and shift then it would drop down to 2* any suggestions?Oh i still have stock l67 injectors.
  2. #2 Re: Injector duty cycle
    What kind of tune do you have?
    GT Level Member afallucco's Avatar
    Ohio
    As I said in the other thread Any knock is bad even a few degrees. What tuning have you done and do you have someone who can tune the car for you?
    Sent from my ADR6400L using Tapatalk 2
    2004 Grand Prix GTP
    |FWI | HP Tuner | 1.9 Rockers | SD Headers | 3.5MPS | 97-03 control arms w/GMPP sway bar|
    Planned soon: s3x, custom ported heads, IC
    Thug life, that's how we live.
  4. #4 Re: Injector duty cycle
    Baytown,TX
    hp tuning
    Ohio
    Have you done a wideband tune and what's your afr?
    2004 Grand Prix GTP
  6. #6 Re: Injector duty cycle
    Baytown,TX
    have to ask my tuner i think he said around 12?? cont remember not done a wideband yet what should the afrs be
  7. #7 Re: Injector duty cycle
    Topeka, KS
    11.1-11.3ish at WOT
    I mean you can go leaner but that's upto you. Sounds like your running too lean!
  8. #8 Re: Injector duty cycle
    Baytown,TX
    its too small even with the xp cam??
  9. #9 Re: Injector duty cycle
    Baytown,TX
    thanks for your help and info guys goin to install injectors and scan will post more info tomorrow
  10. #10 Re: Injector duty cycle
    Out West
    pulley is too small. -- if your duty cycles are 125 you're too rich.
    Whine with your Cheese?
  11. #11 Re: Injector duty cycle
    Baytown,TX
    yea i bought some 60lbs seimens injectors cheap goin to put them on and tune see what happens
  12. #12 Re: Injector duty cycle
    Topeka, KS
    Ya but he said his tuner said the afr was around 12. That's kinda lean if that's true. With the xp it almost sounds like he can't get enough fuel at 125 inj duty.
  13. #13 Re: Injector duty cycle
    Topeka, KS
    I think it's fine i personally think your running out of injector and going lean. I can't see that without a scan though.
  14. #14 Re: Injector duty cycle
    Out West
    still seems rich 125% duty -- you're def running out of injectors though
  15. #15 Re: Injector duty cycle
    Feb 2009
    flintnasty MI
    Quote Originally Posted by Nixon View Post
    The 04+ read incorrectly... He is still well within his functional range on that car... a 3.4 pulley with any cam will not max out stock injectors on any GTP... He can command a bit more fuel if he is really lean without hurting anything.
    I imagine there is a bunk maf file on there that was loaded for the northstar that is leaning things out (because it was richened too much at idle).
  16. #16 Re: Injector duty cycle
    Topeka, KS
    Don't forget you have to change your tune for those injectors. You just can't slap em on without doing anything to the computer. I'm sure you know this but i'm just telling you just in case ya know.
  17. #17 Re: Injector duty cycle
    Baytown,TX
    installed 60lbs injects duty cycle is at 48% now and AFRs at 11.3 wot but i still get about 6* then it goes back to 1*
  18. #18 Re: Injector duty cycle
    Out West
    burst kr.
    Ohio
    Quote Originally Posted by rynoman03 View Post
    You want around 11.5 afr for non intercooled and 12 for intercooled. In this case he's lean
    2004 Grand Prix GTP
  1. ses light cycle time?
    By oneil.GTP in forum General Tech Discussion
    Last Post: 09-25-2010, 08:40 AM
  2. Jury duty.
    By TheOtherNick in forum The Rant Forum
    Last Post: 03-14-2010, 09:04 PM
  3. 121% Injector duty cycle with stock car
    By DanGTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2008, 08:20 PM
  4. 99% Injector duty
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2008, 11:13 PM
  5. Injectors, what is the max duty cycle?
    By Stonewall in forum PCM Tuning
    Last Post: 03-16-2008, 09:49 AM
