Thread: engine wiring harness
Results 1 to 5 of 5
  1. #1 engine wiring harness
    SE Level Member xBlacKxGTPx's Avatar
    springdale ar
    how hard is it to replace a wiring harness in the gtp? i would like to take mine out and put new wire cover on it and install it in the motor before installing it back in the car. would be worth the trouble?
  2. #2 Re: engine wiring harness
    why take it out, just remove the old wire loom, and install new loom of your color choice.
  3. #3 Re: engine wiring harness
    springdale ar
    thats what i plan on doing i was just courios if there might possibly be a main connector that i could unplug to do it in the house on my work station. but it looks like ill be getting som fresh air
  4. #4 Re: engine wiring harness
    Quincy, Mass
    if you take off the back of the fuse box you will 3 bolts. i believe the middle one is for the engine harness.
    replacing all the loom is pita though
    No more GP 04 Impala SS Indy:
  5. #5 Re: engine wiring harness
    You do that one connector, then disconnect everything on the motor and enjoy that rear O2 sensor connector. It's a blast to pull outta it's shield.
  1. 98 gtp engine wiring harness
    By doyleQ in forum Wanted To Buy - Parts
    Last Post: 03-03-2012, 01:12 AM
  2. Anybody have a 97 engine harness wiring diagram?
    By Cutlass3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2010, 09:46 AM
  3. Engine wiring harness ground location?
    By PCweber in forum General Tech Discussion
    Last Post: 09-24-2009, 01:10 PM
  4. engine wiring harness
    By aligater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-11-2009, 08:32 PM
